Tags on Neatitems mf
bandit
What is the best way to remove the tags from Neatitems mf towels without a lot of trouble? Seems like this could be a Big PIA. Thanks:sosad
Wrap the tag around your finger with some tension. You will see the tag pull away from the stitching a bit. Cut along the gaps you made (nail grooming scissors work great), after that you can pull out the remainder of the tag with some tweezers. I hope that made sense, worked well for me.
Adam
Adam
I'd second that:up
Thanks for the info. Seems as if they could issue these towels without tags and save everyone a lot of trouble.
I don't think the towels can be imported without tags. We had this discussion before. If you do a search on MF tags, you'll see lots of info like that, along with a step by step procedure with pics on the best way to remove them easily.
elite towels from microfibertech are tagless.. i got them in a pack of 25, which means 25 less towels to de-tag. :)
although this is my first post, i've been a fervent reader on this forum for a long while. i've learned much from here, and have had pretty much every question i ever had answered by searching, which is why i never posted much before. =P
later!
