Swissvax Mystery vs BMW 530i
El Camino Kid said:
I love those rims on the beamer!:spot
Those rims brought out the BLING! I forgot to add that after cleaning it with Swissvax WHEEL, it got protected by Swissvax Autobahn Wheel Wax with PTFE (Teflon). Very easy to apply/remove and a pleasant smell.
maxi said:
tod which foam pad did y use to apply mystery?
I used the foam side of the Swissvax black applicator pad. A little softer than the yellow pads. I think I'll try something similar to the CG ones next time.
I can't recommend it more. I've tried these applicators with different Zymol EG's and a couple of different Swissvax products and they work GREAT. Much better than the Pete's 53 I bought with them. :D
They really allow you to put the wax on nice and thin which makes it REAL easy to remove. Plus I get a more uniform coating than I do with my bare hands. The only down side is it takes a little wax to prime the pad. I suppose you could keep used pads in a zip lock bag and re-use them so you don't have to keep priming them. I keep cleaning mine. I keep cleaning mine, but if you were concerned about wasting wax you could try that.
wow Mike I thought I had alot of nubas you take the cake i think you have every major nuba on here :-)
Hmm. I used the foam side of the swissvax pad and didnt get much out of it. Oh well, I bout the ones mikeyc talked aobut.
