If the blue pad is like my blue sonus pad then it is a polishing pad and that in conjunction with SSR1 is probably the reason you had little success. A slightly courser pad, and SSR2.5 should start to give you some results, this may leave a slight marring of the surface, which you can easily remove with the polishing pad and SSR1 or AIO etc.
If its drying out too fast, try and do the car in the shade, and you could also add a spritz of water onto the pad to act as a lube, which should give you a little more time to 'work' the product.
