I am still seeing swirls/light scratches after 3 coats of Z5. If I now want to try a swirl/scratch remover, do I need to got through the Dawn wash procedure again?
Could I instead just spray the affected areas (hood) with some IPA/water mix, use the SMR, and then IPA the area again and then go back to Z5??
Also, does the Z5 really fill in the swirls...I'm seeing minimal results after 3 coats? Maybe it takes 5-6 coats?
Thanks for any comments/advice.
