SUPERCAR buddy - Porsche GT3 just detail by Seech & KC
imported_doug
My buddy brought over his car today for some TLC. The car is a year old, has 7000 miles on it (good for him - he <strong class='bbc'>drives[/b] it!). The car has been washed improperly in that time, and it really had some pretty ugly swirls - clearly visible in broad daylight. (sorry, no before pictures. )
<strong class='bbc'>Products/Steps/Techniques Used:[/b]
1. We started by washing the car. Dried with leaf blower followed by blotting with terry towel, and finally wiping with a microfiber drying towel. (Griot's 11117)
2. There were a considerable number of above-surface defects, so out came the clay bar. I used both a Mother's and a new AutoSol bar - both with Meguiar's Final Inspection for lubricant. Within minutes the finish was smooth and soft as a baby's butt.
3. Next we went after a few of the more prominent scratches by hand. For this I used Scratch-X - and I was very impressed with it's performance. Unlike the experience on the Porsche, it actually DID not only fill/hide but REMOVE some of these scratches.
3) The swirls were bad enough I knew that SMR wouldn't be enough - so the first machine step was 3M Finesse-IT II Finishing Material. This was applied with a Meguiar's foam polishing pad - the kind that screws right into the orbital. For everything else, I used the velcro backing plate and velcro-backed pads. I used the orbital cranked all the way up to 6, with good firm pressure until the material started to haze/dry, and then successive passes at lighter and lighter pressure. The result was better than I had hoped for - the swirls were significantly reduced and the the gloss level was quote good. I don't know if the Ferrari paint is softer or harder than the Porsche, but there was definitely less of a haze from this compound than I've experienced before. My friend started to get excited. He followed me and buffed out the residue with Meguiar's Ultimate Wipe towels. The FIII is a little hard to remove - I find it comes off much easier with the aid of a little of the Final Inspection. This step took the longest - probably 1.5 hours.
4) Next I applied Meguiar's Swirl Remover 2.0. Orbital on 6 with a white polishing pad. This stuff is excellent. I think it is easier to use than the 3M SMR - it doesn't seem to look bad if you fail to work it enough, where this is a real problem with the 3M stuff. It is also much easier to remove the residue. Anyway, the SM2.0 got rid of any remaining haze left by the Finesse-IT II, and brought out a beautful gloss. Once again my buddy followed and buffed out. This went a good bit faster - probably 45 minutes.
5) Now I lowered the orbital speed to 4, put on a soft finishing pad and applied the Gold Class Liquid wax. This goes very fast - since all you're doing is applying it, evening it out, working it in a little bit. You don't need to linger.
6) Lunch time - we went for a burger while the Gold Class cured. We only had about 45 minutes, but the conditions were nice and dry and the stuff was ready to buff out when we returned.
7) Buffed out the Gold Class with the orbital on 4, and Meguiar's Ultimate Bonnet stretched over a soft-buff finishing pad. This gets 99% of the wax off really easily. We followed up with Ultimate Wipes and we were all done.
Conclusions: I'm jealous. I wish the Porsche paint responded as well. The car looked FABULOUS. Incredible gloss and depth. The entire process, not counting lunch, took just a little over 3 hours.
<strong class='bbc'>Mistakes made:[/b]
I had 2 scares, both of which could have been prevented if I was a little more careful. First, I didn't remove my watch and managed to create what appeared to be a really nasty scractch pulling the wipe through some of the FI-II. Went right after it with the Scratch-X - 100% gone. I couldn't believe it - thouoght I was toast, it looked so bad - but maybe I just compressed/spread some of the FI-II around - anyway - dodged a bullet there.
Also, at one point I mistakenly lifted the orbital at speed 6 with the Meguiar's pad on. It started to spin (this is to be expected) and achieved a high enough speed that it tore about 3/4 of the foam away from the red vinyl backing plate. I didn't notice this, and while working down into one of the 360's glorious concave curves, the foam pad worked up and the side of the backing plate touched the car. It left a really nasty looking scar, but fortunately for me this turned out to be only transferred vinyl. Scratch-X to the rescue - gone without a trace. That's 2 strikes - time to slow down and be way more careful.
Fortunately there were no other mistakes or close calls, but I know I should have been even more careful.
Anyway - the car looks great, my friend is happy, and so am I (although my back is a wee bit sore... ;) ) Before he left we parked it next to the Porsche in my driveway for a few glamour shots. My driveway has never been happier :D
<strong class='bbc'>More pics at:[/b]
Ferrari 360 Detail Session
Cheers!
Very impressive looking results there Greg!
Must be nice to be able to detail a friend's Ferrari on a Thursday (and not have to go to the office!) and tomorrow worry about whether you should spend some time with your 996TT or your M5!
Your buddy owes you...big time! :)
god im soooo jealous of u. how do u get all these nice cars and have friends with all these nice cars??? the results on that ferarri is amazing...
wow! makes me want to go back to using gold class good enough to make those expensive cars look that great good enough to use on my integra hey carguy what do u use for the windows,vinyl and tires?
hefty -
I don't have pet products in these areas. I use windex on glass. Zymol (whose products I don't generally recommend) has an excellent vinyl care product - doesn't leave a lot of gloss around.
Great job and great pictures! This definately shows how significant good techniques are, not just the products.
You are one lucky man...
Way to go Greg! I bet your buddy is very appreciative of the clean car and more importantly the knowledge that he gained to be able to maintain his own car. :up
Carguy-
I second your opinion on the Meguiar's Swirl Remover 2.0. I just got my PC in the mail today and went to work on some haze and fine swirls I had on my '01 Corvette...the Meguiar's responded better than i could've hoped...particularly since I had bad luck with 3M SMR by hand.
How durable do you think the Meguiar's SMR is? Is it a filler like IHG; will the swirls come back? I hope not 'cause the car looks great right now!
Nice cars, BTW. I can only dream...
What a fantastic job you did. Your buddy must be thrilled. I forsee a little "Ferrari payback" in your future.
And I guess we can see why Meguiar's was on 21 of the 26 Best In Class cars at the last Pebble Beach Concours d'Elegance. What a shine!
awesome..:up ....never heard of the Autosol clay before....were there certain areas or situations you used the Autosol and others for mother's...again...great job+pictures look like ....welll.nuff said...:D
<em class='bbc'>Originally posted by iforcev8 [/i]
<strong class='bbc'>Good to see you rich guys do your own detailing! [/b]</blockquote>
What is meant by this? I find it rather offensive.
Sorry if you found it offensive, but it was not directed to you. Everytime I see a guy or gal driving an exotic, I figure they pay to have it detailed by a pro. I meant it actually as a compliment to carguy. Implying that the even though he has the $$$ to have it done professonally, he enjoys to do it himself professionally, which is why I was so impressed, which is why I posted what I posted.
Some responses:
Schwa72 - I don't really know how the SM 2.0 will be over time. I did the spoiled on the Porsche today with exactly the same products (FI-II, SM 2.0, GC-wax) so I'll keep an eye on it...
PowerSlave - if it serves as a Meguiar's ad, so be it. I have tried a lot of stuff, and there's way more I haven't tried. I like the stuff I use, and a lot of it happens to be Meguiar's. I don't work for them, although I once met an area rep who taught me some things and helped me pick the right products.
FLONI - I can't even remember where I got the AutoSol. It was from a mail-order place when I ordered some other goodies - could have been Griots, CMA, or ??? Anyway, it is blue, but very similar to the Mother's - I didn't use the two for different purposes - I wanted my buddy to feel how the clay bar worked so I put him to work with the Mother's while I tried the AutoSol for the 1st time.
/Carguy aka Greg
Greg-
I'll tell you what, if the 2.0 lasts, I'm a believer -- it's a breeze to use and it's outstanding in appearance. I can't imagine it's all that much different than 3M SMR, so hopefully it's got some real abrasives to it and not just fillers.
I'm a Zaino loyalist myself, so eventually I'll have to Dawn-wash the car (to get the 2.0's oils off) in order to properly re-apply my Z-5. In the meantime, I've just removed as much of the 2.0 as I could with the PC and a terry bonnet, and slapped some Z-2 on there. I know this is a no-no, but it's held up for me well in the past, and it should be okay until my next car wash.
Anyway, thanks for clueing me in to the 2.0...so far so good!!
Did I happen to mention that you have some really nice cars? ;)
