addicted2detail
Hi there!!! I'm Gavin from Australia. Recently I purchased a Porter Cable 7428 Rotary Buffer from the US and so requires a step down transformer. The problem is I do not know how many watts I will needed to do the job. Is there anyone who knows how many watts of step down transformer I needed. I have been told that I need about 10 (Amps) x 120 VAC = 1200watts. Is the calculation correct? Here is the spec: Porter-Cable 7 inches Variable-Speed Polisher
Model 7428
Specifications
Power 120 VAC, 60 HZ Only
Motor Amps 10
No-load Speed 1,000-3,000 RPM
Spindle Thread Type 5/8 - 11 RH
Gear Drive Spiral/Bevel
Wheel/Pad Size 7 inches
Length 17 1/2 inches
Net Weight 8 lbs.
Shipping Weight 9 1/2 lbs.
Model 7428
Specifications
Motor Amps 10
Net Weight 8 lbs.
