Hi to everyone Found HD uno in the UK by chance. I am using a Das 6 prp also have the new meg 220 and a mak 8020
The problem i am having is i am not getting the results you guys do
I had a 2010 Audi R8 cab to do the other day very few marks on it except on the engine lid there was a very small half circle which had burned into the clear coat.
You had to catch the light just right to see it, as i am an OLD type i would have removed it by using either 3M finese in the first instant working it gently by hand, that is how i saw the problem
So i thought try HD Uno with a 3M yellow padon the Das machine set to 4. It was quite a small area so i used 4 pea dots of product on the pad.
Uno just didnt seem to touch it i must have been applying pressure as the backing plate dug into the back of the yellow foam pad
Another question is how do you know when uno is worked in enough to remove or add more to the pad
As the pattern the pad produces dosent seem to change ie it does go clear
Please help as i have an old car i can pratice on it seems a great product it must be user error on my part which i want to get over
