Some conversation between Kevin Brown and Barry Theal
Barry Theal
I have been playing around alot with some new methods of paint polishing and trying to take things to another level. I had a few ?'s and thought I would contact Kevin Brown. For those of you who don't know Kevin, I had the chance to get to talk with him a few times over the last year and he is a man of integrity, knowledge, and passion. A true assest to this business. Anyways I have been trying to find a new way finish down paint. I'm working on a few new techniques and ideas. When I sent the below email to Kevin his reply was simply amazing and we thought this would be a thread for all to veiw. Below is my email to him then his response! hopefully you all enjoy. Thanks Kevin I got a reply coming soon in email.
So I finally broke down and got real serious with your method. Its been going
nice. I wondered something though over the past week and began to think a
little. Not sure if thats good or not. I wanted to run something by you here and
see what you thought. When finishing down with m205. As a Non Diminish abrasive
how do you truly get the most flawless paint possible? If the abrasive truly
doesn't diminish how can there not be any super microscopic scratches? Next I
began to think about the whole jeweling thing or what I call burnishing. Working
the paint with a Diminishing abrasive polish to refine the paint as much as
possible to gain the most gloss. Although when finishing down with your method
its looks outstanding. I began to wonder could you take it another step. So at
this point I was like a kid in science class. Trying different pads and
different abrasives. What if you were to entirely remove the abrasive and use
just the pad for finishing. Obviously you can't just spin a pad across the paint
and exspect anything. When using your method I think a big part is the
lubrication from the water. KInda like when your wetsanding the more water the
less the abrasive yor paper will be. So as the search went on. I found you need
a lubricant to keep the pad moving while only using your pad as the abrasive. So
I moved onto quick detailers and such and found that you can finish down with
Final Inspection Spray. If makes a great lube as well as cleans the paint free
of the oils from the polishes. Once trying this I ran the pc at speed 3 after 2
lights mists of final inspection and boom I burnished paint with a pc and had
amazing results. It made the paint feel clean but it had a crisp look to it.
Some would think I'm nuts for this. Your a man who I'm sure a few thought were
nuts when you said how about serious correction with a pc. Anyways ever try
something like this? Does it make sense to you? Or am I just nuts lol. Let me
know what you think?
Barry Theal
PresidentialDetails.com
717-875-8686
Hi Barry-
I will respond section by section.
If something doesn't make sense or seems out of place, it is because I wrote a bit at a time (then moved things around as I went along).
"So I finally broke down and got real serious with your method. Its been going
see what you thought. When finishing down with m205..."
Nice to see you playing around with polishing. Not a lot of guys take the time to think about what is happening during the polishing process. However, I think it is a must for guys that want to be better than very good. Let's chat!
Unless the paint is "brand new" (freshly sprayed and not touched) there is bound to be scratches, whether the human eye can see them or not.
This is an opinion- but I suspect not too many guys would disagree. If you fall into this category, then we see eye to eye so far. So yes- there are microscopic scratches present. For the sake of argument, let's assume that we are always refining the scratched paint surface (either by smoothing its shape or eliminating big scratches and replacing them with smaller ones).
To bolster this opinion, we can certainly look at the effects that glazes, oils, and fillers have on our perception of the paint surface. After all, if the paint is perfectly smooth, would we see a better reflection if we "topped" the paint with some sort of transparent product (the "topper")? We may see more "depth" because we have added thickness to the surface (so the paint color would be literally farther away from the top point of the glaze or wax), but not more accurate reflection. In fact, unless the topper was self leveling, we may see a decrease in reflective accuracy.
We probably should consider what these scratches look like.
Are the scratches shaped like a "V"? Or, are they shaped like a "channel" (channel meaning that the shape would be similar to a square minus the top line)? If the scratches are "V" shaped, our buffing abrasives are more readily able to polish the sides of the scratch and smooth the points where the top of the scratch meets the paint's uppermost surface. These scratches are certainly the most common, as a piece of grit or hard material usually cuts into the paint like a knife blade (thinly at first, then wider as the scratch deepens). If the scratches are channel shaped, the scratch is not as easy to hide via smoothing, so more paint must be removed in order to eliminate them. These scratches are usually created when an object is pushed across the surface, without an ability to dig deeper (such as when somebody places a cardboard box on the truck and slides it). Any dirt between the box and paint either rolls between them, or the dirt gets attached to the box and acts like a piece of sandpaper. Better yet- imagine that the teeth of a hair comb made of steel is rubbed against the paint, and the ends of the teeth are square instead of pointed.
Now... let's discuss our abrasive materials.
In most cases, buffing liquids and pads should be considered abrasive (we'll stick to foam pads for this discussion).
Since most pads are designed to contour to the painted panel, they tend to ride upon the painted surface rather than dig in. Their action is similar to what happens with paint cleaning clay. Unless the shape of the individual membranes are aggressive or sharp (or if someone decided to mix abrasive particles in with the foam slurry), the foam will create scratches that are fairly consistently shaped, and with similar depths. This assumes that the pad is not falling apart, or the walls of the membranes are not sticking together and then flipping upon each other, creating bulky clumps). If we add a lot of downward force to the pad in order to compress it and the foam can NO LONGER reshape to the panel (or the foam becomes reasonably compressed), it will then create inconsistently deep scratches (mostly due to panel shape). So, final polishing is typically done with super soft and pliable pads, devoid of harsh membrane structures. By harsh, I mean bumpy.
"As a Non Diminish abrasive, how do you truly get the most flawless paint possible?"
"If the abrasive truly doesn't diminish, how can there not be any super microscopic scratches?"
You asked about non diminishing abrasives.
In the case of the superfine stuff being used these days, the individual particles generally create a smaller and more consistently shaped scratch than the materials used to make the pads. So, you might want to think of these in this manner. Abrasive, yes. But not detrimental to the surface. If the abrasive particles are evenly dispersed across the pad and they rub across the paint in tandem (tightly packed against each other, not clumped, and on the same plane) you should see a great result. It is likely that if we could grab just one abrasive particle and push it across the paint surface, we likely would NOT be able to see the scratch it created.
"Next I began to think about the whole jeweling thing or what I call burnishing."
So, what about "jeweling" or "burnishing"?
Those are terms that essentially define the final polish step to me. When I used to do a five or six step rotary session, I personally did not have names for each step (I just paired pad with paint with process). Then again, I was buffing using multi-step processes prior to the time when there was any Internet-based forum discussion about polishing, so I suppose if I was explaining things by "steps" and using names for the steps, I might have referred to them by similar names.
What you guys are basically doing is trying to use the pad's abrasive capabilities to polish the paint in the least invasive manner, while still affecting the paint surface. A coating of liquid applied to the buffing pad's membrane-like structure and the paint surface itself might act as a "buffer" (in this case meaning to lessen or moderate the impact of something). Think of it this way: First, the liquid coats the surfaces, so only the tallest points not within the layer of liquid are fully exposed or mostly exposed.
To better visualize this, think of the ocean and the land above the sea level on Earth. In this case, let's slice off a small piece of Earth and place it on a very large table (a square mile will do). You are in charge of water management. Your goal is to keep the water in the ocean, and the dry land dry. The water will stay on the table unless you take action to remove it via bucket, squeegee, push broom, or via heat (thus evaporation).
Just as in reality, your ocean covers most of the Earth's surface. If you wanted to push broom or evaporate the ocean away, it would be a massive undertaking. Now, imagine a storm rolled in and wet all of the dry land. Although the land would be wet, the layer of water would be very thin (compared to the depth of the ocean). Heat from the sun would evaporate the thin layer of water in a hurry, and you could squeegee away any water lying upon hard or flat surfaces (you would push it right back into the ocean). The remaining uneven land surfaces holding pooled water could be either scooped away or soaked up with absorbent materials. This scenario is very similar to what we are doing with a foam pad.
In reference to water or lubricating agents in general:
Since liquids are not easily compressed (most times they are deemed to be not compressible for simplicity sake), the layer of liquid might cause the pad to "float" or ride atop the liquid to some degree. If the pad also features a layer of liquid spread across it, the net effect might be one that sees only minimal contact between the pad and paint surface. Consequently, only the highest of points of the paint surface are being affected, and the newly formed paint surface would lack sharp or inconsistently shaped features.
To envision this, imagine that you are going to skip a rock across a pond of water, and the water is at rest (so its surface is basically flat). The pool of water has small pieces of grass sticking through the top, and you want to cut a path through the grass so that it is flush with the water level. You sharpen the edge of the rock so it will cut through, and you make sure when you throw the rock, it has a lot of rotational speed.
This scenario is very similar to what is likely occurring during your "burnishing" step when you polish paint with a finishing polish. In this case, the pond water represents the liquid covering the paint, the grass blades represent the high points of paint that your pad is going to "cut through", and the rock represents your buffing pad. Not a perfect analogy, but I hope you get the gist of the comparison.
"...Working the paint with a Diminishing abrasive polish to refine the paint as much as possible
to gain the most gloss (burnishing)."
Not necessarily.
This assumes that the abrasive, once fully diminished, will be smaller in size and more consistently shaped than the current crop of non-diminishing micro-abrasives used in products like M205. Besides, what about abrasives that do not attach well to the foam membrane structure very well? What if someone came up with a particle that was mostly smooth, except it featured a buffering agent that allowed only the tiniest points of the particle to protrude and possibly attach to the pad? Most of the particles would have to be pushed along the paint surface by the pad. The remaining loose particles would either be positioned between the pad and paint (rolling between the two), or they would simply be squeegeed across the paint by the pad's membrane-like structure. Interesting.
"What if you were to entirely remove the abrasive and use just the pad for finishing?"Could you use a buffing liquid that does not contain abrasives and just use the buffing pad to reshape the paint surface? Sure! As long as the pad is as previously discussed... as long as it does have some abrasive capability... and as long as the guy using it keeps it clean and understands how it interacts with the surface.... then a quality result could be realized. As with all other products used to polish paint, one paint-type will respond better than another, so it is something to keep in the arsenal but would likely not deliver the results you might be hoping for on most paints. Again- if you see great results, then more power to you. If Final Inspection works well, a softer pad (or a softened pad) paired with water as your short term lube might yield similar results.
"When using your method I think a big part is the lubrication from the water."
Not sure if you are referring to using the rotary or using the random orbital here.
While water certainly seems to alter the cut, it usually results in a bit more haziness of the surface. I have written about using a spritz of water to increase the cut with the rotary, but do not generally recommend implementing it with the random orbital. Do I personally do it? YES, but not always. I am a stickler when it comes to keeping my pads clean (which is probably one of the top reasons I tend to see better polishing results than the next guy). If the pad is not kept clean (especially when using a water spritz), the abrasives and paint residue tend to pack onto the surface of the pad or into the membrane structure, and stay there. A big reason for this? Typically, there is not a lot of centrifugal motion occurring (because there is less high speed rotation of the pad), so the residues tend to stay where they are compared to using the same setup with a rotary.
"Kinda like when your wetsanding the more water the less the abrasive your paper will be."
Are you referring to a hydroplaning effect, so to speak?
I think you are meaning that if too much water is present between the sandpaper and paint, then the paper essentially glides atop the water until enough escapes. The correct amount of water? Water would be present in the valleys between the abrasive particles, and a minimal amount would be present between the points of the particles and the paint. Enough to float away abraded paint residue. I think we are on the same page here.
Now consider this: What if you were to use only sandpaper to polish the paint?
You would start out sanding with a paper than features large particles first, then once you leveled the surface sufficiently, you would then use papers featuring finer particles. This process would continue until your eye could not discern any surface defects. By using sandpaper, you would have created a very leveled surface, especially if you paper was not flexible from one point to the next. Most panels we sand or polish are not laser-level, so we need to utilize papers that can conform to the panel. We therefore need some flexibility, but only enough to allow the paper as a whole to contour to the panel shape. If the paper changed shape every time a piece of sanding grit encountered a high point or low point, we would only succeed in thinning the film build without evening the surface from one point to the next. Again- this is similar to how paint cleaning clay operates, except the abrasives stay level to the surface because the clay contours to the surface. The clay and its abrasives have a very hard time digging in, so true leveling is not going to happen. But- can you imagine how accurate the reflection would be if we polished the paint via sanding rather than use a pad and abrasive?!
It could be pretty stunning. For the most part, the paint surface would feature a very smooth looking surface, one that would reflect accurately. Think of a typical orange, but imagine if it was a smooth metal sphere that had been painted. If we progressively sanded the surface, we would certainly see a consistently shaped layer of paint, when compared to an identical orange that had been polished using a buffer, pad, and buffing liquid. The only standout defects might be tracers that had not been thoroughly removed during subsequent steps, but their would be no high points, only valleys.
We could get a similar type finish with machine polishing if we could spin the pad fast enough.
Heat is our biggest problem. Next, the inability to see the paint through the buffing liquids could lead to disaster. The abrasive particles that were able to attach to the pad would move at the speed of the pad, effectively acting as a sanding disc. The remaining loose particles would be pushed along, eventually tumbling and adjusting disposition. In a way, they might act as little spheres (think of ball bearings), and they would either be forced into the paint or slide across it, grinding the away at the paint surface. They might also act as a hard barrier, effectively negating any pad/paint contact. You've seen this for sure- lots of guys refer to it as "gumming". Gumming either occurs because of what has just been outlined, or because the pad cannot "squeegee" the product from the surface. Instead, the pad simply rolls over the product.
"So I moved onto quick detailers and such and found that you can finish down with Final Inspection Spray.
It makes a great lube as well as cleans the paint free of the oils from the polishes."
You mentioned that the Final Inspection cleans the surface (removing the oils) while acting as a lube.
True, to a point. The "oil & water do not mix" dynamic certainly applies to a degree. The Final Inspection lifts or displaces the oil (moving it away from the surface and the pad via centrifugal force to some level), revealing clean paint and pad surfaces. The Final Inspection would also act as a lubrication until it evaporated (more rapidly than a typical petroleum or other lube material). It's just like when we spritz the paint with water when using a rotary and a wool pad. The pad is minimally cleaned because some of the attached abrasive particles loosen, the paint is cleaned (to some degree and dependent upon many things). It also wets the fibers, making them pliable again, eventually allowing them to straighten and pack tightly against each other (effectively increasing the amount of wool present in any measured area, such as a square-inch).
Does it make sense to you? Or am I just nuts? lol. Let me know what you think.
Barry Theal
Not nuts at all.
I suspect that in the future we will be utilizing some pretty incredible stuff.
Perhaps we'll have buffing liquids that are sprayable. They will contain very fine, hard particle abrasives. The pads will likely have pockets that can release small amounts of moisture so that the abrasives can be worked longer before they dust away.
We may even see a point when the pads are impregnated with the abrasive particles (which will be super hard, like diamond dust), and we will spray a lube of some sort upon the surface. This would be ideal, because all we would need to do is clean the pad with compressed air during their use. Once the session ended, we could then wash them to remove stuck-on contamination. The only dusting we would encounter would be remnants of the pad and the residues we buffed away.
Your turn to let me know what you think.
If this all makes sense, perhaps we could/should post it to a forum, as I think people would enjoy the read.
Kevin
A few thoughts:
One thing you'd need to know about final polishes is just how small they break down. That is proprietary information and I doubt that any manufacturer is going to spill the beans and even if one did chances aren't you wouldn't have another one to compare with. Factor in the abrasiveness of the pads. Pore size and density both play a role in how fine the pad finishes. Again, some pads are similar and some dissimilar. Third factor in the machine. A PC produces a different pattern than a rotary and works the abrasives differently. The speed the pad rotates also plays a role in how fast and small the abrasives break down. Some abrasives are a 9 on the MOHR scale with a 10 being a diamond. I doubt these abrasives truly break all the way down-again proprietary info.
Some pads are already impregnated with microscopic abrasives. They are used mainly for glass and stone working. I have some 3 inchers that attach to a drill which rotates much faster than a PC. They finish quite nicely but definitely lack cut.
I like the concept of burnishing the paint with a QD but if you don't have enough lubrication you run the risk of actually slightly hazing the paint. Remember most polishes are full of oils to buffer the abrasives and pad. You'd have to experiment with burnishing with different QD's and different machines and different pads. A fine closed cell pad would probably work best.
One factor not addressed is the size of the orbit and higher speed. A PC and Flex have rather large orbits. My Rigid 2611 has a smaller orbit. I find the 2611 to be about as effective with a 6.5 inch pad as a PC with a 4 inch pad. The smaller orbit should result in less dragging of the abrasive across the paint and potentially less microscopic gouging.
In the case of the superfine stuff being used these days, the individual particles generally create a smaller and more consistently shaped scratch than the materials used to make the pads. So, you might want to think of these in this manner. Abrasive, yes. But not detrimental to the surface. If the abrasive particles are evenly dispersed across the pad and they rub across the paint in tandem (tightly packed against each other, not clumped, and on the same plane) you should see a great result. It is likely that if we could grab just one abrasive particle and push it across the paint surface, we likely would NOT be able to see the scratch it created. (end quote)
First the pad is part of the equation. The pad and polish create the cut-it isn't one or the other. A fine pad in combination with a fine abrasive should result in a finer finish than a courser pad and the same polish-as long as the abrasives can be broken down. Personally I haven't had good luck using super soft pads with the PC. I always seem to get better results from firmer pads. IMO that is because the firmer pad produces more friction more fully breaking down the abrasives.
If a finishing polish is 5% abrasives and 95% lube it's going to be awful hard to distribute that 5% of abrasives across the pad face evenly without supersaturating the pad-is it not?
wannafbody said:
...One factor not addressed is the size of the orbit and higher speed. A PC and Flex have rather large orbits...
...(A smaller) orbit should result in less dragging of the abrasive across the paint and potentially less microscopic gouging.
Perhaps, but it would be related to abraded paint residue or other debris packing around the abrasive particles.
Notwithstanding, the depth of the scratch created by the abrasives would cut into the paint the same depth, regardless the distance it traveled.
If there were only four abrasive particles stuck to the buffing pad (spaced apart), and the scratches created by them dragging across the surface were visible, large circles would likely be more visible than small ones. Meaning, if one machine featured a 1-inch stroke, the scratch would likely stand out more readily that a machine featuring a 1/128" stroke (in this case, the "circles" might look like pinholes!)
This all relies upon the premise that only attached abrasive particles would affect the paint surface. Usually, we are dealing with both attached and unattached abrasive particles, so the loose ones can fine polish scratches created by the attached ones. Some of the particles may even act as rolling spheres, cutting a much smaller depth gouge into the paint surface. They may even prohibit the pad from touching the paint. Ahh, so much to think about.
A similar discussion came up on another forum a while back, but it was pertaining to sanding with a either a small or large diameter orbit.
the_invisible said:
I have successfully removed sanding marks with the orange pad and M105 on the DAXP on OEM paint as well. One or two cynical skeptics harassed me for the sinful act of removing sanding marks with the DA + foam pad. The orbital range of the PC, or Griot's, G110 for that matter, are a little long compared to dedicated air powered sanding tools. I will have to give my DA a try for wetsanding.
Kevin Brown said:
... I agree that most of us correlate fine sanding with the need for a small stroke machine, but after much thought as to why this would be true, I deduced that is is NOT true. My opinion, yes, but it is backed up with a lot of thought (and a decent amount of experience). I also chatted with a few guys on this very topic over the past year (whenever it was on my mind). It was especially helpful to talk to those that had zero experience with sanding (they were just good thinkers). No bias towards large or small stroke. Then, the thought process began.
Bottom line for me? Unless I need to use a machine in a tight area that does not allow safe use of a long stroke machine... or I need a machine to be used on a surface that requires precise control, I will opt for the large stroke machine every time.
There are many reasons for this, but one of the biggest reasons is obvious if taken to an extreme.
First, eliminate the random rotation of the backing plate (which is driven by centripetal force, but more on that in a bit). Imagine a machine that only created a 1/128th-inch stroke, and we are using a six-inch sanding disc. The machine's miniscule movement would essentially bore tiny little holes in the paint, and any abraded paint material would probably not move away from the abrasive particle, so we would likely see pig-tailing as the abraded paint residue packed itself around the individual sanding grains.
Now, switch to a machine touting a two-inch stroke. Obviously, the stroke on this machine would not allow for safe use in a confined area because the backing plate's side could bash into surrounding parts. Plus, the area being sanded will be larger (effectively an 8-inch diameter area versus an area of 6-1/128th inch for the small stroke machine).
The speed of the particle's movement per oscillation will be higher with the larger stroke, so cutting power increases, as does the distance each particle moves. This increases the likelihood that the abraded paint will eventually migrate away from the abrasive grain that removed it in the first place. Lots of lateral movement, so there is a high likelihood that the residue (and any sanding grains that have detached from the disc) will not become trapped under the disc.
If the sanding disc is durable and high quality in terms of particle size and distribution, the sanding will still be thorough. In other words, if the abrasives are super refined, the placement and sizing of the abrasives are magnificently controlled and durability is very good, then the sanding disc is taken out of the equation.
As for the random rotation of the backing plate... all other parameters being equal, the rotation will be higher because more movement creates more centripetal force...
I am at work right now but this looks like i really need to sit down and give this 100% of my attention later tonight. Barry and Kevin thank you guys for posting your insight and ideas on the polishing process, can't wait to read this later and also see what else may come out of this particular thread!
Nice post Barry. I'm going to have to give this some more thought. This could definitely propel the technology within the polishing world of what we do....but I can't help but have the thought that while this makes for a good rhetorical discussion, if it is not visible to human eye, is such a level of burnishing worth it? When do we start delving into the world of diminishing returns?
At the same time, some great think-tank discussion here that could lead to some wild new product development with practical applications.
First, I neglected to mention that there are zero cut pads. Paring a firm zero cut pad with a fine finishing polish should teoretically result in the best possible finish. I've never used the LC red pads so I can't comment but for some reason on a PC I've never gotten a great finish from the Megs tan pad. Another issue is open cell vs closed cell pads. I use ZPC on my TA and find that the close cell pads don't dry out as fast as an open cell pad-in other words they allow the polish to stay on the pad instead of working into the pores of the pad and airflow through the pad is more as well.
With a smaller orbit it would seem to me as if you be more effectively working a smaller section of paint since the pad is traveling less distance from top to bottom and side to side. This allows the polish to be fully broken down over less surface area of the paint allow for more and more refinement of that particular area. The downside is that if you don't fully break down the more aggressive polishes you will end up with more concentrated holograms-just like a rotary.
Nicsand claims that a 1.2 micron abrasive is the smallest that the eye can detect.
I think D Tailor brings up one of the most interesting questions: diminishing returns. I think that's an important thing to consider especially if you throw in how easy it is to marr some paint. Polishing until you get the clear-coat/ss as perfect as a human eye can detect means nothing if you'll compromise the work by simply wiping the polish residue off the surface.
As for the conversion and OP - GREAT information and discussion. Thanks for taking the time to share such information with the community. A lot of good points and ideas were brought up. I plan on rereading again tonight
Jeweling is only effective for a dedicated show car that is almost always kept inside. One swipe with a MF and chances are you've instilled micromarring that can't even be noticed on a light color but on dark blue mettallic in bright sunlight you realize that the hour you spent on the hood just went bye bye.
bufferbarry- Thanks for posting that, and for giving us some good food for thought.
Hmm..never thought of trying that with the #34; it kinda sounds like a less-aggressive version of how we used to "hand rub" lacquer with cotton and Meg's #7 back in the day; the cotton did the abrading and the #7 provided lubrication.
Kevin Brown- Hi, Kevin. Always appreciate your insights on this stuff!
wannafbody- I too prefer not-too-soft pads via DA/RO, even for very mild work.
MuttGrunt & D Tailor- Whenever I bother doing the burnishing, the results certainly are very subtle. I usually can't see anything significant in the shop, but I do notice a "certain something" in natural sunlight. Note that this is *after* I've predisposed myself to the opinion that it was a waste of time, so I don't think it's "seeing what I want to see". Also, my wife usually notices that something's different even if she can't quite say what the difference is ("did you use a different product on the S8?").
The degradation of this sort of finish definitely *does* occur, but not as quickly as one might imagine, at least not in my (probably very unusual) situation. But no argument at all about diminishing returns, so this isn't something that I bother doing on a regular basis. And on a "normal person's" car... eh, what's the point if somebody's gonna just micromar it with the first wash?
Im glad everyone enjoyed this. There is a lot of great info here. For me I love to learn the why things work. I will keep playing and always playing around. I'm just glad I had the chance to share this incredible information with everyone.
Excellent piece to read. This thread has plenty of invaluable information and fix many parts of the puzzle in my past details. Many occurance do makes sense now and I got to re-think of some of my assumptions in the polishing stage. Thanks so much for the sharing.
Here's my thoughts, right now, I can't get a decent day to detail (I'm a weekend part timer) so I can't test my theory. The theory? That a Cyclo using M105 would work as well or better than a simular PC/PCXP with the same pad due to the longer stroke the Cyclo has. And I've asked on a few boards and no one has tried it that I know of.
Who says that detailing isn't rocket science?? Kevin Brown was taken polishing methodology to level few will ever think about except those developing polishing compounds and the "trade secret oils" (TSOs) and liquids used to protect the paint or deliver the abrasive particles.
One thought on abrasives is that most natural occuring abrasives have some geometric shape to them, usually a cube or mulit-faceted form. What if someone developed a "buckyball" synthetic shape with many edges in a uniform, nano-sized shape? The size and hardness of an abrasive particle are contributing factors to how well an abrasive will polish, but in my opinion, it is the shape of the abrasive that contributes the most to the polishing physics. However, as Mr. Brown points out, the techique and pad used by the detailer are probably of greater importance
than the polish being used.
I am sure someone somewhere is working on this synthetic abrasive. (Think M305/S or Synthethic PO106FF/S)
JuneBug said:
..[perhaps].. a Cyclo using M105 would work as well or better than a simular PC/PCXP with the same pad due to the longer stroke the Cyclo has..
If by "with the same pad" you mean "with the same 4" pad", the PC always behaves more aggressively than the Cyclo for me when the PC is fitted with a 4" pad.
I've yet to try M105 via Cyclo as it works so well for me via Flex/PC 4". I can't help but wonder if the Cyclo might flash the M105 too fast, the way it does (at least for me) with KAIO. I'm just guessing, but I'd expect a whole lotta pad cleaning to be required.
Heh heh, considering how much I love my Cyclos, the fact that I've never tried M105 with them probably means I'm pretty concerned about such stuff. But hey, I've been wrong plenty of times!
Now the Cyclo/M105/SurBuf with water combo...*that* might be worth a try for seriously aggressive work.
