KnuckleBuckett said:I was informed that 105 (now on its way to my house) has more cut than Menz Powergloss.
SuperBee364 said:Having PO106FF, SIP, and M105 makes a nice, well-rounded arsenal.
KnuckleBuckett said:I wonder why Menz Powergloss gets so little press in the forum. I have had excellent results with it and value it in my aresenal.
Mindflux said:PG isn't popular because there are a host of items cheaper that finish down better than PG. M105 being one of those that will polish out deeper scratches than PG could ever do and finish to a level where you could use a final polish and move onto your LSP.
Picus said:105 has a lot more cut than SIP, a lot. 105 is a heavy cutting compound, SIP is a moderate cut at best. I don't think it's silly to have both at all. I know a lot of guys go from 105 right to 106ff, but I think having all three is smart. That pretty much takes you from a very heavy cut to an ultra fine polish.
Zet said:There aren't that many compounds that cut more than PG, and I think it actually finishes down ok for the cut. But I hate the way it dusts. For me it wasn't before M105 arrived that it has become obsolete.
Rob Tomlin said:I'm gonna jump on this bandwagon and order m105!
Question for those who have used it: can you expect to go straight from 105 to 106FF with good results? I very much prefer to have no more than two polishing steps.
SuperBee364 said:A qualified "yes"... Getting the technique down with 105 is the tricky part. I'm still learning it, and I can't get it to finish down really nice 100% of the time yet. When you do get it to finish down correctly, you could even jump to PO85RD and skip 106 most of the time. Yeah, it finishes *that* nice. When you don't quite get it to finish off really well, on most clears you could go right to 106. UF is a good choice, too.
Rob Tomlin said:Thanks Supe. So if I understand you correctly, even if you don't finish 105 off that great, 106FF should clean it up on most clears?
