Reflectiveauto
i doubt it is on there strong like cquarts or opti-coat, im betting either a light polish with something like po85rd on a black pad or am205 on a black pad will work to remove it mechanically. chemically can try some prep solvent which you can find at car quest if they have a paint department. fyi, never fall into the dealership coatings, most of the time they are a scam. also you dont have teflon on your seat, its probably the same active ingredient in scotchguard professional or 303 high tech fabric guard. teflon does not bond until a very high temp, if it was applied at that high temp, well you would not have a seat left. as far as screwing yourself out of opti-coat, doubtfull as you can remove it. however the surface needs to be near perfect before applying the opti-coat as it would be pointless to seal in the swirls and scratches you cannot remove once the opti-coat is applied. but since you need to do this i would do a full two step proccess on your paint as im pretty sure it has dealer applied swirls. so something along the lines of the blackfire SRC compound and blackfire polish, meguiars m105 and meguiars m205, optimum hyper compound spray and hyper compound polish should all be a great 2 step (apply compounds with 5.5" orange FLAT lc pad on da and polishes using a white or black lc 5.5" flat pad) and it will remove the simonize product as well as remove any existing swirl marks/defects in your paint.
edit: since you are in CT you can get the microfiber DA system and the meguiars DA at these two walmarts located in ct(im from rhode island and my dad lives there so i keep an eye out for stuff like this for him)
CT BRISTOL 1400 FARMINGTON AVE
CT WATERBURY 910 WOLCOTT ST
good luck!
Just leave outside with that monster storm coming your way...that should remove the sealant.
