jw said:Thanks Legacy, Does blue have more bite or less than black? I have white or black. Also, what's the process for jeweling? Is it the same as polishing?
Legacy99 said:Both are finishing pads, but the blue is softer. It is the same process as polishing, however, most will rush this last step in order to get the LSP on. After jeweling I use a paint cleaner before waxing. Pinnacle Paintwork Cleansing Lotion is what I use. The outcome is dramatic. I almost hate to touch it at this point, but it must be topped with a wax. Swissvax cleaning fluid has been highly recommended and I have it on order. Little pricecy, but oh well, you'll never know until you try it.
Legacy99 said:BTW take you time doing this last step. Jeweling can take as long as polishing.
YankeeFan said:That seems awfully pricey to me to wipe off remnants of polishing. Wouldn't an IA/water mixture suffice to wipe it down?
jw said:I'll give the po85rd a try tonight. .. Should I use Zaio or AIO before the Wolfgang Fusion?
SuperBee364 said:An IPA wipedown should always be considered necessary after using any polish (and before LSP) and especially after using Menz polishes. The only way you'll know if you got all the holos out and got the correction you want is by doing a very thorough IPA wipedown after polishing. After the IPA wipedown is where I apply the PCL, glaze, or whatever pre-LSP I'm using (if any).
jw said:Does blue have more bite or less than black?
jw said:I'll give the po85rd a try tonight. I don't have PCL. I was planning on doing an IPA wipedown when done. Mayb washing it and then apply Wolfgang Fusion. Should I use Zaio or AIO before the Wolfgang Fusion?
termigator said:Can you use FP II instead of PO85rd? Got loads of FP II.
Also, when you say IPA (Isopropyl alcohol?) wipedown, are we diluting it or going straight?
Accumulator said:Noting that I've never used PO85RD...IIRC it's *extremely* mild. IME Zaino's AIO has abrasives that are (at least in regard to initial bite) *more* aggressive than some polishes I've used. So I'd be a little leery of using ZAIO on paint that's been thoroughly burnished with something extremely mild.
On the Audis, I jewel/burnish with stuff that's a lot milder (in terms of initial cut, not necessarily in terms of final finish) than ZAIO so I'd never "go back up the scale" so to speak.
The Klasse AIO is so close to functionally nonabrasive that I don't think it'd be too likely to diminish the finish that the PO85RD leaves behind.
But if *I* did the burnishing with PO85RD, I'd a) give a lot of thought to what I used between that an the LSP (yeah, PCL is nice) and b) be *VERY* careful with any washes/etc. as I'd sure hate to somehow instill new marring on the highly jeweled finish.
Other side of the fence on this one (gee, how often do you and I disagree about anything?!?).
I *never* do IPA wipedowns after my burnishing steps, in part because I don't want to remove what some of my burnishing polishes leave behind (but I don't do it after polishes that finish cleanly either). I don't even *start* burnishing until the finish is as corrected as I want it, so there's no fear of uncovering any flaws; maybe that makes all the difference and our approaches are just not directly comparable :think:
Also, I don't bother doing any wipedowns before PCL as it *is* a paint cleaner. Yeah, PCL can do a little concealing of its own so I can see not wanting to use it until you're certain of the paint's (true) condition...maybe this just gets back to our approaching this step differently. By the time I reach for PCL I'm *finished* polishing, period, and ready to clean things up and glaze 'em via the PCL.
Yeah...I suspect that what you'd call "the initial burnishing step" is what I'd call "the final pre-burnishing polishing step". IMO there's a potential for some overlap in terminology here.
Thought occurs to me: actually, on some *very* soft paint, the PCL could actually be used *for* the burnishing; a least my (older) version has a *tiny* bit of cut to it, but I hear the current version is a bit milder.
IMO it's not really a question of "bite" as the pads used for jeweling/burnishing are generally functionally nonabrasive (so all the minimal cut comes from the product), or at least that's how *I* approach it. Unless you're dealing with very soft paint all these finishing/waxing/etc. pads will be functionally nonabrasive.
The big thing is that certain products just work best with certain pads, it's often a question of the pad's porosity and/or how it soaks up product (or OTOH how well it keeps the product down on the panel *instead* of soaking it up).
jw said:I'm confused now. If I use the Po85rd can I go right to Fuzion after? I though I had to do either a wash or Wipedown to get rid of any oils?
termigator said:IMO, FPII and 85RD are in two completely different categories...[explanation follows]...
YankeeFan said:So....let me get this straight. PCL is a cleaner but also fills swirls? If that is true, then does the filling agents (not sure what to call them) in PCL compromise the effectiveness of a sealant? And I assume if you are using Duragloss, it would negate the need for 601.
Howard
