Short Video: Polishing Nissan GTR
Anthony O.
Not sure if I should of posted this in the "Polishing" section or here in the "Product" section because it's a little of both really.
This is a short video of me working on a black Nissan GTR using (as of this date) soon to be released Lake Country pads called "Kompressor". These pads are designed to cut down on sling and also provide very smooth operation which is due to how the pad is able to flex and take on body panel contours.
This is accomplished by way of the pads face being cut or sliced in a unique manner which leaves the pads face with numerous "blades". These blades "compress" with the weight of the polisher and this allows the pad to more easily take on the shape of the area being polished. Another benefit is that because of the blades there is no sling whatsoever (provided correct product amount is used). In our testing these Kompressor pads also seem to have a better cutting ability than their same ppi counterparts.
These pads work well with orbitals also such as the Flex orbital and so far have proven to hold up through numerous cleaning using Lake Country's pad washer. Upon first inspection I figured these pads would get messed up easily by way of the "foam blades" being ripped up on edges and such and also perhaps be a potential risk at holding debris but both of those initial thoughts have proven to be false. These pads are very durable and do not hold debris within the foam blades.
I have used the pads with various products such as Menzerna FPII, IP, Meguiars 105, 205 and also Optimum Polish and as seen in this video Optimum's yet unreleased Finishing Polish.
The new Optimum Finishing Polish is, so far, a wonderful product and although Ron and I have limited use with this new beta version, what we have seen so far has been impressive. Long working times, finishes down excellent, easy wipe off and is orbital friendly. I am looking forward to more testing with the new Optimum Finishing Polish, these new Kompressor pads and also some even newer pads Lake Country is working on.
I believe that many of you will take to these new Kompressor pads and they will soon be your favorite pads to reach for. I know they are for me as of right now. They will soon be available.
As for this video - We had a Nissan GTR come into our shop for a ding removal on the driver side rear quarter panel. As Ron worked his magic on that I had a chance to speak with the GTRs owner and he expressed his displeasure with how the paint was looking (caused by what he believes to be careless workers at a car wash) so I inspected the paint with some lighting and went about cleaning and then polishing a small area to see how the paint would react.
He was right, the paint was very scratched so I went with the Flex orbital, green pad and Optimum Polish II. This combo cleaned the paint up fairly well, enough to impress the owner and catch his interest in further paint correction. I then switched to a finishing pad and used the new Optimum finishing polish (OFP) which further brightened up the paint. He was sold and 2 days later booked an appointment for an exterior only paint correction.
I then began some research into this "self healing" paint Nissan has put out on the GTR. Sadly not much is out there nor have many detailers had a great deal of experience with it but from what I had read and from my limited hands on experience I theorized that many detailers were attacking this rather unconventional paint through conventional means, this theory was further solidified upon the GTR's return to our shop as all the scratching where I had polished re-appeared! Ron and I were very puzzled about this because what we had read about this "self healing" paint is that it should "self heal" after several hours or days from minor abrasions to its surface.
The more we fiddled with the paint the more I became convinced this paint needs to be treated with a different mindset. A call by Ron to Nissan North America confirmed this as they had very little information to give us (not their fault but rather it's an OEM matter) so we are now going to work with Nissan of North America and perhaps develop a "standard" method of care for this paint type. The issue is that the nature of this paint may actually work against detailers who go at the paint with an aggressive means to level out the scratches so instead of going at the paint with a cutting pad (orange, yellow or wool) which would of been my normal first thought had this been a typical paint finish (due to the severe marring/deep RIDs), and a leveling compound such as 105 or 3M's Extra Cut I opted for Lake Country's new white Kompressor pad and Optimum's new Finishing Polish (I also used 3M's Ultrafina. Trading off panels so as to compare the two products).
Being that the weather was chilly we brought the car in, closed the shop up and turned on a heat lamp which not only provided excellent working light but also heated up the panels we worked on. This paint supposedly works through heat to aide in its purported healing process so we figured we would warm up a panel first before polishing. The combo I had chosen cleared the paint up quickly, which really surprised me because my first choice, which was more aggressive, did not clear up the paint as well nor as fast. I am under the belief now that heat, more so than friction (by way of abrasives) is the best manner to go with in correcting this paint type.
So we went with 1500 rpm's for the first pass (white Kompressor pads/finishing polishes) and worked slowly, allowing slightly more heat build up than normal and used slower than normal passes. After that pass we switched to black foam finishing pads (also kompressor pads) and the same polishes. We worked the same speeds but with lower rpm's, 1000 to be exact (tapering off from 1500). Our last step was black foam (again kompressor) and the Flex orbital. We then Opti-Sealed the paint and we were finished. We were happy with the results and more importantly the owner was very happy.
Nissan of North America is waiting for us to get back with them in a week to see if the paint correction holds or if the marring returns. The owner is on the PGA tour at the moment so the car is just sitting in his garage which is perfect for our test. He will bring it in for a wash upon his arrival back in town.
We will give an update along with pictures........it was dark when he arrived so we hope for pictures next time.
Here is the short video: YouTube - Paint Polishing
Anthony
:welcome back there Anthony.
I have been waiting to hear what others have to say about correcting these self-repairing finishes. So, the finer the abrasive, the less chance of the marring reappearing (in combination with heat)? Looking forward to the video.
Anthony, Very Informative write up so far, THANK YOU! By the way the video link is not showing up (for me at least?) I am very interested in your findings as I have a Black Nissan GTR Job scheduled for next month. I checked under the hood and saw the sticker stating "Hard Clear". Is this the same "Self Healing" clear you are talking about? Thanks
Hello all and thanks for the welcome back messages.
I fixed the link, sorry about that.
Here it is also: YouTube - Paint Polishing
the GTR paint is a different animal, alcohol wipe downs tend to make the paint grabby more so than other conventional paints. My plan or method may not be correct so I am interested in not only hearing from others in their experiences but also doing more of these cars to see if it is the same standard across the board.
Take care,
Anthony
Great video Anthony. Thanks for putting it together. It seems that the initail hype over the GTR has died. I know severa of my clients that backed out of their deals and moved on to other cars.
I saw a TV show once a few years ago with 'self healing' paint.
They pored boiling water over it to get rid of scratches.
It would be good to see if it works!
I thought the info about the (Lake Country pads called "Kompressor"), wasn't supposed to be out of the bag yet. I concur, they are great pads that work well.
Hey People,
Thanks for the positive feedback on the write up and video.
tdekany- It's the Flex 3403. I really like the Flex polishers, so much so that I now have the Flex orbital plus I also run 2 3403's. One with a 3inch backing plate and another with a 6inch backing plate.
Thanks again guys and I hope to get some feedback from others and their experience with these GTR's.
Adios,
Anthony
Anthony Orosco said:
Hey People,
Adios,
Anthony
Thanks for the info Anthony. I was asking for Conan777, he is considering it along with the makita. I'd guess you like the Flex better than the Makita? If I remeber correctly you had Makitas before right?
Also, what backing plate is that? The Megs Solo?
Thanks Anthony!
BigAl3 said:
how do you like it? also... how often do you use it?
On a daily basis. I am a loyal fan of the cyclo but the Flex orbital gets more done with greater versatility in terms of pads selection. Although I did use the cyclo the other day in some areas where the Flex orbital could not fit very well so it's great to have both tools within reach.
Anthony
nice, one can never have enough tools for all sorts of different jobs these days.. once again, welcome back! :)
Thanks Anthony!
We also use a Makita so I can give a fair comparison of the two. For me it's hands down the Flex over the Makita. The Flex feels better in my hands, is very light and easy to control. It feels much more like an extension of your hands. The one area I dislike on the Flex is the rpm control dial.....well I like it for its easy reach position yet I also dislike that it's within easy reach, if that makes any sense.
Hope that helps,
Anthony
David Fermani said:
I thought he was using a Metabo? If I remember correctly, there was a video of him buffing 1 handed with 2 of them?
Hey David.....yes that's correct I normally used a Metabo for a good number of years and loved the older styles but didn't have much love the newer version even though it had more torque.
My Metabo is sitting on the side lines waiting for a repair but it seems all the parts I need for the repair and "discontinued":down
Anthony
