mrclean81
I use some stuff from Superior Products called Zap It, but there are many out there that do the same thing. Superior is easily accessible for me, so thats what I use.
No but I have considered getting a backing plate to accommodate one of the 4 inch brushes made for a Cyclo. Im not sure of the stiffness of either. Normal brushes are hard on cloth seats but Im sure these brushes are soft and made for this use. I'll have to give it a shot some time.
The brushes would work really well for carpet and scrubbing the seats, but the advantage of the pad is it absorbs the cleaner and makes the seats dry very quickly.
This sounds like a great idea except how do you rinse the foam out of the seats?
I use a Mytee HP60 Extractor all the time on cloth seats and I don't soak them so badly that I cant extract almost all the water out. For my cleaner I will use Meguiars APC+ either at a 10:1 or a stronger mixture - 7oz APC+ and fill the rest with water in a 32oz bottle..
Dan F
MrClean81, what RPM setting did you use on your rotary? Thanks in advance!
So mrclean have you tried this with a DA? I was thinking I might get a little bit of 'scubbing' action with a PC. And what kind of foam do you think would work best? Maybe a harder foam like white?
^^You should go into business that's a million dollar idea:bigups
Yes the pad I used on these was twisted wool. I like them because they are thicker than the foamed wool and absorb a lot of the cleaners. The only down side is they will at times shed some of the wool and throw it all over the car. Ive had this happen twice. Not really a huge deal if you have an air compressor to just blow it back out, but if someone didnt have air it could cost them a few minutes of time wiping everything back down.
For some reason I'm thinking this may be a little bit like the dentist telling you that, "you're going to feel just a little bit of pressure".
Regardless, I'm probably gonna try it, because it looks like it really works well.
Like I stated in the first post, Im not claiming anything other than it works. Im a pro detailer, not a scientist who breaks down everything that's happening until it doesn't make sense. Im sure there are some who will say "this sounds too aggressive and it might disturb a cloth fiber, so this is a bad idea". Those are the ones who have never cleaned a filthy seat in their life. Real world problems require real world solutions imo.
I actually only meant to quote this part: "The only down side is they will at times shed some of the wool and throw it all over the car."
I found it a little funny because I've had wool pads "shed some of the wool" , and it went EVERYWHERE.. I was not questioning anything else about your process - I think it looks like a pretty good idea.
