1997 Jaguar XK-8 Convertible in a Charcoal Black Metallic with Black Interior.
When I arrived, no doubt you could tell this thing was neglected. It was dirty all over, swirled pretty badly, the rims were gashed and covered in brake dust and the interior was just plain dirty.
I begun with the interior using Water Woolite (6:1) to clean the seats, dash, and trim. I then used my OxyClean mixture (2 scoops:2 gals water) for the carpets after pretreating them with Simple Green. I then dressed the dash and trim with 303 AeroSpace and conditioned the leather with Lexol.
On to the exterior, like I said VERY SWIRLED. The hood and trunk lid needed 3 separate passes. My final process was:
-QEW
-Wolfgang Clay w/QEW Spray Lube (1 capful:32oz water)
-WW Dry
-#80 Speed Glaze via Rotary and Meguiar's Polishing Pad @1500rpm (numerous passes in some areas)
-VM via Rotary and LC Polishing Pad @1000 rpm (very light pressure)
-EX-P by hand
-Simple Green to de-grease wheels
-VM to polish wheels
-AA on tires and wheel wells
Here is a good shot of what the swirls were looking like. You can see some cob-web effect and on the trunk lid some spots where the owner used rubbing compound to probably fix a scratch. BAD NEWS!
After 2 separate passes with #80 and then VM/EX-P
In the end, everything turned out quite nicely. He was happy, but not thrilled. He's not much of a car enthusiast even though his taste is there. You can tell he doesn't care much for the vehicle by the way he keeps it. I was very happy with the results though
-QEW
-WW Dry
-EX-P by hand
