wannafbody
wannafbody
mbkintner said:A - Using what works for you = good sound advice
B - Why would ZPC clean better than any other polish that has comparable abrasiveness and provides a comparable finish?
C - Quite possible.
D - This is where I disagree. If the goal is to produce a good finish prior to the LSP then Sal shouldn't be suggesting that the LSP be the solution to haziness. If in fact, ZPC doesn't work well with some paints then the suggestion should be to try an alternative product that does, then use Z2 and/or Z5.
Mike
B- honestly I don't know what is in ZPC that makes it clean so well but it cleans much better than other polishes I've tried
D-I'd suggest talking to Sal about that. He'd probably tell you to use your favorite finishing polish. He's well aware that some people absolutely rave about ZPC while others get slightly better results from other finishing polishes. One thing he'd say for certain is that every other polish available has oils in it and must be followed by an ISO wipedown.
