BlueZero said:You can use some products like Meguiar's #7 right away.
jnick said:This is good to know, especially since I just bought a new car.
Thanks for bringing up the topic, bert31!
It could hinder the paint from curing properly and you might wind up with softer than normal paint to deal with. The best alternative is to use a "new paint" safe glaze like Meg's #5 (very easy to use). I'd reapply it often and even though it won't last much longer than through a wash it offers some protection and is very easy and quick to apply.Patman said:Technically speaking, what would happen if you were to put a sealant on a one week old paint job? My biggest concern would be if a bird took aim on that brand new finish, I'd want to have some sort of protection on there!
smprince1 said:I would say for new cars you can apply a sealant or wax right away as the paint has been cured at the factory.
For repaints, I would wait 90-120 days before applying a sealant or wax to allow the paint to fully cure.
keep_it_clean said:not always true. cars that are damaged during shipiping will go to body shop and get repainted. i have seen it done. i work at body shop.
stiffdogg06 said:Aren't that baked in the dealers ovens?:nixweiss
bert31 said:I didnt' think dealers' body shops had ovens, only the manufacturer did.
BlueZero said:Probably 8 years ago or so I needed some painting done and went to a bunch of body shops. From what I remember only one had a oven. He said he didn't use it all that much. I don't have a clue how hot they get but would think that you can't just stick a whole car in it. Other stuff would melt if it was too hot. Most of the time then don't take off panels for a touch up. Just some thoughts.
bert31 said:That is what I was thinking. At the manufacturer, when the bake the car, the panels are either a) not attached to the car's frame yet or b) nothing that could be damaged from extreme heat is in the car yet such as tires, upholstery, wirring, the plastic dash, etc..
I just can't see how a dealer body shop could afford the cost of one of these ovens and to go to all of the work to remove the panels. That overhead cost would result in the paint job costing thousands of dollars.
Lots of body shops have what you might call an oven, but the difference (as some have mentioned) is they aren't nearly as hot as what they can use at a factory on a bare car/panels.stiffdogg06 said:Aren't that baked in the dealers ovens?:nixweiss
