travisdecpn
Resident of Detail City
This article may help http://www.bettercarcare.com/articles.php?articleId=15
swirls said:1.Heavy compound(red) if needed. Wool pad just for heavy
2.Light Compound(white)Ardex 1500 or Malco Buff Light II. Wool Pad just for light
3.Swirl Remover with Foam Pad
4.Either Glaze or wipe swirl remover with micro fiber.
Paint looks great, no swirls. 1 month down the road swirls will show unless it's waxed again.
swirls said:I don't think anything removes swirls, it just fills them in temporarily until the car is washed a few times. You can't remove them, they are very small scratches in the paint and all you can do is use the finest grit compound there is so they aren't as noticeable then glaze. Synthetic compound is BS, on clearcoat it's just going to remove dirt and dead paint, it is impossible for it to cut into clearcoat with no grit, it won't remove swirls either. Just use the finest grit light compound, flatten out the pad, buff with little pressure, and don't buff in 20 directions or the swirls will show even worse. I know if you're buffing a hood try to go from the front all the way to the back 'cause if you stop in the middle the swirls will be worse.
swirls said:First of all those aren't swirls. Those scratches weren't caused by a buffer. Second of all the car doen't have a spec of dust on it so it was just washed and waxed.
Sveta said:Very nice, blkyukon!
Was that done with a DA or a rotary? Hope it's with a DA cause that is very nice results. Care to share your process, etc.? I don't achieve that level of "bling" at all.
