Rupes LHR 21ES Random Orbital Polisher - Features & Benefits
I was rotary for many years. I would have never thought a perfect finish could be acheived with a DA. Until a couple years ago and MF pads my mind has been changed. Im seeing near LSP ready finishes with MF compound pads/M105 and a 7424 XP. Technology has changed. There was a little learning curve but can now only count a few time the rotary came out. I know this will be my next machine over a Flex. Just need to talk some with the "Buff Daddy"
What about the Cyclo? It's got a long stoke and the limiting factor (IMHO) is that no one makes a 4" MF pad........WHY? I have a white Suburban coming in this weekend and the Cyclo with orange pads using a mix of M101 (BIG THANKS to Mike Napoli) and D300. I'm using this combo over my PC's with MF and my rotary cause this beast is big, but just needs a good 1 step. I figure I'm covering 8" or more with each pass, plus my hands just can't take the vibes from the PC for the amount of time required to do this thing.
I am interested in your new machine, hope to see some vids on YouTube about it.
Optimum Microfiber Cutting Pad - 4.25" | Free Shipping Available - Detailed Image
JuneBug said:
Tried Surbuf and didn't care for them.
Same here...but I did want to mention them for use via Cyclo.
So *nobody* sells a 4" MF cutting pad?!? Seems odd since you can get 'em in 3", which I'd consider more of an oddball size. Eh, guess there are a lot of 3" polishers in the Pro realm...
How about these?
I have a few but let's not steer away from the OT ;)
Optimum Microfiber Polishing Pad, 4.25" : Amazon.com : Automotive
This is just how easy it is to use the LHR21e, my friend came down a few days ago and wanted some Bigfoot training, so I gave him hard Audi paint and the LHR21 with a green Rupes pad and Rupes Zephir and he produced some awesome results, and this guy has NEVER picked up any type of polishing machine in his life! He now wants to polish more paint, he couldn't believe how easy it was and that the machine has no vibration at all even with a 21mm throw at full speed!
For reference Im using the LHR15e.
Miracle Detail Training Day using the Rupes Bigfoot System - YouTube
Kind Regards
Paul Dalton
Miracle Detail.
Tel: 07788-441150
Office: 07788-441150
Int'l: +44 (0) 7788-441150
Email: [email protected]
Web: Miracle Detail - Car detailing - Paintwork Correction
Youtube: Miracle Detail aka Paul Dalton - YouTube
Twitter: Paul Dalton (MiracleDetailUK) on Twitter
Facebook: http://www.facebook.com/Miracledetail
Nice video, Paul!
For some reason I feel like going dancing now though....could be the killer beats in the vid. :dance
C. Charles Hahn said:
Looks like I'll be making a trip to the post office later... came home to a delivery attempt notice on my door.
No need to hurry to the post office Charles. I saved you a trip and had the shipment forwarded to my place. Anything for a bud.lol.
As much as I love the forums, there's no denying the power of Facebook. A lot of chatter regarding the BigFoot, so I figured I'd copy and paste some of it here (this way it'll be easier to find down the line). For the record, the entire thread can be found here, and was based off of a thread started here.
Rupes LHR 21ES: "The King of Cut"
Lots of discussion about the Rupes® BigFoot 5" LHR15ES versus the 6" LHR21ES.
"Are the backing plates interchangeable?"
"Can I use the 5" plate on the 6" machine?"
"Which is the best one?"
The backing plates ARE interchange between the machines.
The hard plastic portion of the plates are the same exact HEIGHT.
The 5" and 6" plate WEIGH nearly or exactly the same:
Repeated weigh-ins of the 5" plate showed a variance of 0-6 grams.
Repeated weigh-ins of the 6" plate showed a variance of 0-6 grams.
Rupes 5" buffing pad.
Rupes 6" buffing pad.
The blue & gray plastic portion of the backing plates measure:
5" plate - 117mm diameter / 6" plate - 130mm diameter
• The Velcro portion of the plates measure:
5" plate: 125mm or 4-7/8" actual / 6" plate: 148mm or 5-7/8" actual
• The white foam is 12mm tall on the 5" plate.
Its side features a somewhat squared side, flaring only 4mm top to bottom.
• The white foam is 9mm tall on the 6" plate.
Its side features a somewhat flared edge, flaring 9mm top to bottom.
So... there won't be any "balancing issues" due to weight variance. However, should you decide to swap the 5" plate onto the 6" machine, it will FEEL different partly because the plate's foam sections are not similar at all (plus other reasons, to follow).
Continuing on with the 5" plate on the 6" machine:
The 6" LHR 21ES may not FEEL as balanced as the 5" LHR 15ES because there is 40% more "throw" or "offset" with the 6" machine. In addition, the 6" machine utilizes a heavier counterbalance assembly, which compensates for the larger stroke (and perhaps a bit for the potentially heavier pad). The added counterbalance weight is not an issue unless you happen to REALLY be throwing the machine about or; the extra weight may cause more of a steering sensation (if you've ever ridden a "wheelie" down the street on a bicycle and turned the handlebars while the front wheel was spinning, this may make sense). Not really an issue, just something technical I thought about while writing this.
Otherwise, the added weight keeps the backing plate spinning along FASTER and MORE CONSISTENTLY as regular polishing or added friction is encountered (due to panel shapes changes, applied pressure, etc.) This was VERY noticeable during a mini-test session last night. The 6" machine SMOKED the 5" machine in terms of backing plate rotation, and under heavy applied pressure (to test the premise), the 6" machine was the clear winner in keeping the backing plate spinning. Keep in mind that the 5" machine is rated to deliver 5,000 RPM versus 4,200 RPM for the 6"..!
Which machine should YOU choose?
While all of the above SEEMS to show the LHR 21ES as being the clear choice, it was not my intent to make that choice for you. I'm merely stating what I saw to be true. Factually, I think that so many guys are used to using a 5-1/2" pad or disc nowadays, that they may want to stick with the 5" machine for financial reasons (some guys have 100+ 5" pads!), or simply because they're used to using the 5" pad. I think both are great reasons to buy the 5" machine.
It is also true that all other things being equal (machine speed and specs, pads), a machine with a small stroke will FEEL smoother or more balanced (even if its not actually better balanced) because there is less "side bashing" of a pad against a hood bulge, a sharply curved plastic bumper, a body trim piece (or whatever). Or maybe not! A smaller pad means that the platform the machine is riding on (the pad) is less stable because it is not as large or wide (so a tilt of the machine or an encounter with a hood bulge may feel more "bashy" or "abrupt").
I could go on and on, but I wanted to at least relay the fact that the 5" plate will fit on either machine, and depending upon the pad to stick against it... you may or may not feel a "balancing" issue.
Kevin your mind is simply amazing, thank you.
As for yours truly buffing with a product that has no abrasives in it - I've never done that
even glare which I used years ago contains abrasives of some sort, otherwise how does it remove oxidation
since it's solvent based I no longer use it or any other solvent based polish
What I do use though which is as close as what you said Kevin, is for final finishing
Two products from my mentor - The super wet water like High Tech polish as well as the awesome Jewelling polish which is even finer than any finishing polish (85RD, HD polish,speed etc) on the planet. whilst not as runny, it is extremely lubricated without containing alot of oils and is water based which I prefer as it doesnt break down my cars solvent based paint over regular use
it truly is mind blowing how fine this stuff finishes paint using no pressure, slow speed, low arm speed and a short or long stroke machine (dynabrade 61375 with 19mm, the makita bo6030 or metabo sxe450) using a flexipads ivory 110ppi european foam pad
I totally agree with you about short stroke vs long stroke in terms of the abraded paint residue on the pad issue. the metabo sxe400 is a cute and quite powerful machine capable of better than rotary correction of defects. for deeper scratches the rotary of course is better due to the shearing action
with microfibre pads and any technique/speed, the centre of the pad loads up alot which means I'm blowing the pad clean with compressed air alot.
comparing that to the 15mm orbit throw dynabrade polisher, the same pad stays cleaner
keeping the pad free from being loaded up with abraded paint residue is critical
What I've found amazing lately is using the mega ultra fine jewelling polish with a random orbital with a super strong pad (flexipads rayon) at medium speed then slower and slower. the moderate to medium paint damage on th 14 year old factory paint dissappeared and the gloss I got from that was way better than if I had done the traditional thing of cutting with compound and wool or other strong pad then going finer and finer with pads and polishes. once I finished up the panel with the ivory pad, RO and same polish, the result was mind blowing. rock hard paint though it may not work on but soft to medium, oh yeah.
As for the Bigfoot vs Dynabrade 61375 and 85
2mm more throw is a plus for the bigfoot but it doesn't have forced rotation, the rotary behind the dynabrade is 1200 watts vs 500 for the rupes and 3200 rpm is fairly quick and gives the 75 tonnes of power to correct
The 85's RO mode is not as good imho, the plate doesn't freespin and throw itself around the mechanism like the RO only 75. I have taken out all the fine preparation marks in an aussie performance car's OEM paint with that thing using just a microfibre polishing disc. reduced the peel by 25% at the same time
mind you my arm speed was bloody slow
the orbit speed of the rupes is slower than I would like but it totally blows the dynabrade away in terms of comfort and ease of use. one cannot use either dynabrade product on curvy panels unless your highly skilled, it's best for fairly flat panels
but both heads are massively powerful and the strongest tool along with the bigfoot for cutting power but also finishing performance.
the 61375 at speed six with surbuf or microfibre pad not only correct stuff that usually requires sanding but it finishes out fantastic once the speed gets slowed down , pressure released and pad blown clean and a dash more product added just before the end
the only thing holding me back from buying a rupes is that it has been available in Australia for quite some time now and there have been reports of many burning out at crash shops doing normal compounding and polishing duties day in day out.
And it doesnt look as well built as a german tool
price tag here is several hundred here
I say have as many tools as you can, not just one or two. there's a place for a, short and long stroke, big throw or little
Final words - Each machine type gives a certain look to the paint and so does different pad materials
IMHO the forced rotation tools are the best to correct with, the random orbitals are extremely good at both correcting and the last buffing step but can't transform the paint ie retexturise it like a forced or rotary can
And the old rotary with it's shearing action is the ultimate tool for Jewelling the paint. really glasses it out, enhancing colour shade, depth and overall clarity. but I always finish with an random.
will I buy a bigfoot - maybe in 2013 after seeing how long they last in other peoples hands. will it replace all my other tools - no way. it would just be another great tool in my weapons of defect destruction
wish it was 4,000 to 13,000 as with the metabo sxe450 with it's 6mm throw. A surbuf at that speed is deadly to defects
Oh and the LHR75 would be bitching if it had forced rotation which a 75 and 90mm polisher I'm looking to buy soon does have
Wow, impressive write up! Nice job, Kevin! I'm already getting the Rupes...but this made my decision feel like a smart one, ha. I'm getting the LHR75 too!
Kevin its posts like this that truely seperate you from the rest of the pack. I can remember a few years ago when we first started to talk. It was amazing to hear your mind work. Unlike any other person I have ever met. You not only have a passion for correcting and polishing paint, but the way you put it into words is astonishing. I have for one can say you opened my eyes to the way I look at paint. It never ceases to amaze me at things I have learned from you. I knew one way for years, now I find myself being more of a student and nt a know it all anymore. The strange thing is now when ever I teach a class I always fid myself teaching your methods in depth. Its been a blessng to know you. I can order my machines from any company, but itsyur humble ways and openness that keep me coming back to buffdaddy when a new machine its the market. Thank for not only inspiring me, but the may other paint polishing ways. One of these days weneed to get together and sand something!!! :yo:
