Crazy3rdgen
So i bought the run razor kit from eastwood. It came with a plastic planner that uses a razor to shave off the run. It gets down to .001 of an inch. Also came with clay sanding blocks. The kit is seen here if yous are interested.
http://www.eastwoodco.com
Then for product number type 34007
My question is how should I go about doing this? Use the planner to get the run all the way down before hitting the surface of the clear thats smooth. Then just wet sand with 2000? Then what? I only have access to "on the shelf products" right now. And I dont have a buffer.. only a walmart one but they dont count.
