Street Dreams
Thanks David! Excellent information. I've seen guys with a rotary going at it like they're possessed! Mad-fast passes, jacked up to 5000, compound flyin'! Crazy! ( I like your method much better!)
Question:
I've only used a PC and I know with KBM pressure is an essential part of the procedure... basically, keep the pad spinning.
1. For compounding, mid-step, and fine polishing with a rotary, how much pressure is necessary?
2. For compounding, mid-step, and fine polishing with a rotary, what RPM speeds do you recommend?
Compounding with foam, I use more pressure and slower passes keeping that in mind I always feel the panel to see how much heat im generating.
Middle step, depends on what I need to accomplish but moderate pressure usually works for me and I like to really make a lot of passes here to ensure my finishing process can be quick and painless.
Finishing, start off with medium pressure to breakdown the polish and massage out any last holograms and then lighten up to where just the weight of the machine head is pressuring the pad.
