Slightly dripping wet seems to be the best for me
and I also spray down the panels down first
I do this as well. I squeeze the mitt just enough so it doesn`t drip all over the place as I move from the solution bucket to the car, but I want it as wet as possible.I spray the panel before hand then use a Rinseless wash mitt instead of a bunch of microfiber towels. But I keep the mitt pretty wet.
As wet as wet can be. It`s sloppy by safer.
pgp- Not interested in using a larger sprayer? Mine is..what?...1.5 gallon IIRC, and it stays pressurized for ages, long after I`ve done a vehicle it`s still ready to go.
The smaller one looked easier to store, handle was cheaper etc. I usually don`t mix up very much solution at a time. Do you use the sprayer with the long wand and pump handle?
Mine might be leaking or a poor design? I spray a panel or two or three, do a wipe and it`s needs to be pumped up again to displace what I sprayed. I am not happy with it and usually use a standard spray bottle.
