would you say this stacks up favorably against Megs Gold Class...with the exception of the scent? (which is really not important to me)
Really like the videos in your review, helped get a better impression of the product.
Would you say there`s any significant difference between foam gun specific soap and the non-foam gun specific soap (as you used it in the bucket and have experience with lots of popular soaps)? I get that each soap is different in it`s own right but still I`ve been able to use every soap in my foam gun, foam lance, and/or bucket without issue or compromise.
Things I would look for in a foam gun/lance specific soap:
- Higher than 400:1 dilution ratio. As concentration is key for nice foam.
- Cleaning power. It should clean better than a regular car soap without agitation.
- Foam dwell time. It should be more clingy than regular soaps at the same dilution ratio.
- Slow to dry in the sun. Some soaps I`ve used dry very quickly on the paint when in the sun while others dont.
Thanks for the review
- Higher than 400:1 dilution ratio. As concentration is key for nice foam. - I can`t comment as there was no dilution ratio provided on the sample bottle. But it seemed to be around this ration in the bucket as I used the remaining 1.5 oz`s in 3-4 gallons of water. I believe 1 oz would have been sufficient.
- Cleaning power. It should clean better than a regular car soap without agitation. - I can`t answer this since I rinse the car off before foaming it with any soap in either a foam gun or foam cannon.
- Foam dwell time. It should be more clingy than regular soaps at the same dilution ratio. - This one clinged to the surface rather well even in a foam gun. I imagine it would be much better in a foam cannon.
- Slow to dry in the sun. Some soaps I`ve used dry very quickly on the paint when in the sun while others dont. - Good thing you brought this up. I washed it in the sun and the sun was beating down on one side of the car. It was rather hot on the glass so it did dry out rather quickly. I went over that area again to reactivate the soap just in case so I would not have any issues later. This is one of the reasons I use Adams Car Shampoo as it was designed to be ok if it dried on the surface.
:lol2: any more? How do you know our next choice won`t be better![]()
