acuRAS82
This is a review for the new DP “Not Your Father’s” SiO2 Paste Wax (later referred to as “NYF”). Please understand that PBMG provided me with the wax for free, as well as some other DP products to try and review. It`s a ceramic wax from the newly updated DP line. It does not appear to contain any carnauba, but rather polymers / SiO2.
https://www.autopia-carcare.com/dp-sio2-paste-wax.html#.XnMxd3JKiHs
Price:
$44.99 regular retail for 8oz
Product Description:
DP "Not Your Father`s" Paste Wax is just that, not your father’s paste wax, it`s yours. Made for the next generation of detailers, DP "Not Your Father’s" Paste Wax supplies SiO2 protection which results in a slick, high-gloss shine. DP "Not Your Father`s" Paste Wax will last longer than a traditional carnauba wax.
What you can expect:
•SIO2 PROTECTION! Say hello to hydrophobicity and protection!
•SHINES! Prepare for shiny, glossy, slick look!
•MADE TO LAST! Protection and shine will last longer than a typical wax.
Initial Observations:
Scent – Lemon (I’m bad at this, Meghan correct if I’m wrong).
Consistency – Medium / hard, like most other PBMG waxes (think Souveran / Midnight Sun / Fuzion).
Color – Blonde, like the color of the label.
Vehicle / Paint Surface Condition:
Applied to the ol’ 2004 TSX on 03/17/2020. First, stripped previous LSP with coating prep wash. Clayed with BF clay mitt. Polished with a combo of Pinnacle Advanced Swirl Remover (above waist level) and Megs Scratch-X (below waste level) using LC blue & white polishing pads. After polishing I did a few rounds of WG Perfekt Finish Paint Prep on the horizontal panels (hood, roof, trunk lid) and those surfaces are feeling and sounding squeaky clean. For vertical surfaces (sides, front, back) I applied CarPro Essence Extreme primer with Gloss Pads.
NOTE: The horizontal surfaces are being used for a Ceramic Wax test which includes “NYF” SiO2 Paste Wax. This will be detailed in another thread.
The vertical panels have “NYF” SiO2 Paste Wax applied over Essence Extreme.
Application:
As satisfying as a paste wax. I personally love ceramic waxes due to the old school application with modern water behavior and self-cleaning. I grew up using waxes, I enjoy the Sunday afternoon wax-session-nostalgia. But I also am into the self-cleaning and glassy appearance of modern SiO2 products (sprays & ceramic waxes). These waxes bridge the gap for me more-so than the SiO2 sprays (which I also adore but the waxes are my fave). The wipe off is where I really appreciate the ceramic waxes. Once I do an initial wipe of the first panel and get the feel, I know my later wipe offs are fully removing the product. I don’t always feel this way with the SiO2 sprays, where I’m constantly checking angles to ensure I removed uniformly. Since I do a lot of my detailing in my garage at night time, this is an appreciated benefit of ceramic waxes.
It was applied in my garage at about 62 deg F, average western PA humidity (40-50%?).
Directions -
1. Make sure applying this product on a cool surface and out of direct sunlight.
2. If necessary, wash, dry, clay and polish your vehicle before applying this product.
3. Working one section of the car at a time, apply a thin layer of wax to the surface using a polyfoam applicator.
4. Allow approximately 1 to 3 minutes for wax to flash and haze before buffing away.
5. Once 1-3 minutes has passed, buff away with a clean microfiber towel.
6. Continue to do the same thing around the rest of the car.
*If the wax appears to be `smeary`, it is likely that too much wax was applied. In this case, use a coating a prep spray to remove the wax before applying again.*
Much like all PBMG waxes, rub a foam applicator lightly onto the wax surface. The slight heat from friction will cause the wax to melt onto the applicator. Prime the applicator like this once and after that it should only take a swipe or two per panel to reload. Thin is in. The stuff goes pretty far. Considering the 8oz size of the tin, one of these should last for a long time and probably get 30-40 applications (just my rough guess). I had no issues with smearing that is alluded to in the directions.
Unlike some ceramic waxes, this only takes a few minutes to haze and then can be wiped off. I tested both the 3 minute suggested wait time and also intervals of 5, 10 and 20 minutes. It was easiest to wipe off after 3-5 mins but not difficult after 10-20 mins. Just a bit more resistance the longer the wait time.
Results:
Very nice gloss! From my initial impression inside my little garage with poor lighting, it’s a mix between candy shell sealant look and SiO2 glassy. It’s not see-through, crisp, glassy like some coatings and SiO2 sprays like High Gloss, or PBL Surface Coating. It has a certain smooth look to it that I would compare to PBL Sealant. There was possible filling noticed during my wax test comparisons (unless the horizontal areas I applied this naturally had less RIDs). Very good slickness, but not Beadmaker or QD slick… more soft-smooth-slick texture. This is similar with most ceramic waxes I have used.
I have no observation of water behavior, self-cleaning or dust repellency yet. I’ll add information once observed. The car is still in my garage. There is no cure time listed for this wax so I’m assuming it cures pretty fast, but I always try to stick to 24 hours whenever possible for polymer / SiO2 products. The wax does not claim to include carnauba. I’m not sure whether this attracts less, more or the same as competitors… but I wouldn’t consider ceramic waxes to be super attractive to dust.
Final Summary:
I’m very impressed with the value of this wax. Ceramic waxes aren’t cheap and never have been since Dodo Juice Nano Hybrid and PBL Synergy released theirs in 2015-ish (others may have existed before then but these were the first I was introduced to). Other ceramic waxes I have are also in the boutique, pricey range. The closest comparable ceramic wax in value (that I own) is Mckees Krystal SiO2 Paste Wax ($70 for 8oz), but that’s a $15 price increase. I think “NYF” applies/wipes off slightly easier and hazes quicker. IGL EcoCoat Wax is similar price as “NYF” but it’s is a cleaner wax and doesn’t have great longevity, so I’m not sure yet how “NYF” compares.
This wax does pretty well in all categories one would expect from a ceramic wax, upon initial application. Some of the more expensive waxes have effortless wipe off, fantastic self-cleaning, great protection/durability/longevity and insane looks. Those are qualities that are paid a premium for. I think a lot of people are not willing to shell out the money to try those products. I admire that this wax should allow a broader audience to experience ceramic waxes and their benefits. We’ll see how time and environment treat this wax, but after initial use I think it’s a winner for the price.
I apologize for the lengthy review, I get excited by these types of products. Thanks for reading!
Price:
Application:
Directions -
Results:
Final Summary:
