SuperBee364
Car is done. Sprayed on a coat of Opti-Coat 2.0.
In Anthony Orosco's video, he mentioned that you don't need to wipe down "high spots" when spraying. My own results differ a bit from his. I ended up spraying a bit too much on the glass of my sun roof (which was the first thing sprayed). It went kinda milky looking, as an area of over-application would look if you were wiping it on. I did not go over that area with an MF, I just let it cure. It still looks milky, and hitting it with an MF this late in the game did nothing. I did manage to get a few other milky areas, but I went back over them with an MF, which corrected the areas no problem. The key is to not wait too long before knocking down the high spots. I found that anything later than 10 minutes was too late (which I'm sure changes according to temp/humidity).
I used exactly 15 ml of product, coating everything but the wheels and front windshield. All other glass, trim, etc. was coated.
So how's the look? IMO, not as good as Opti-Seal. Not even close, really. There's a trade off... if you want a high gloss traditional sealant, go with Opti-Seal. But if you want an OK looking permanent coating, Opti-Coat is great. I'm not saying that the look isn't acceptable, it's just not as good as many boutique LSP's.
It's too late for pictures today, so I'll try to snap a few when I get back in to town next week, after it's first post-OC bath.
Spraying Opti-Coat is definitely something to consider if you're having problems getting it to look right by wiping it on. Yes, you still have to be concerned with areas of over-application, but they are *easily* taken care of with an MF as long as you don't wait too long.
I think one of the reasons some guys have a hard time with WOWA products is the "did I actually get any on the paint?" factor. With a non-WOWA product, it's darn easy to see that, yup, you really did put something on the paint. With a WOWA, it's often times not that easy. The advantage to spraying is that you can see exactly where the stuff is going, and that yeah, you did actually get it on your paint. It's also pretty easy to discern where you got too much.
Final thoughts...
Opti-SEAL is wonderfully easy to apply with an air brush, and the results are nothing short of stunning.
Opti-COAT is easier *for me* to apply with an air brush than wiping it on. No, it's not a complete no-brainer process like Opti-SEAL is, but it is still very doable, and the results are very good.
Advantages:
Disadvantages:
Final thoughts...
Advantages:
- You can actually *see* the stuff going on your paint
- Anthony Orosco says that you'll get "more of the actives" on your paint by spraying than wiping on
Disadvantages:
- You still do get milky looking areas of over application if you're not *extremely* careful. These areas must still be knocked down with an MF prior to full cure.
- More product used per car.
