Removing Wax... help!!!
Ok, after 1 coat of AIO and 7 or 8 of SG (all done over a matter of weeks) I decided to add 2 coats of blitz to the deal. Know I'm finding streaks from the wax...almost like a haze. I remove it with my fingers and it comes back. I just want to know whats the best way to remove the wax without removing the Klasse. I was thinking some dish soap. Also whats a good rim polsih to use. I found mothers (with kerosene), EO original (with pertolium distillites??Sp?) and EO jewelers rouge (wiht some sort of acid) I just have factory aluminum wheels on my dakota, not sure if there clear coated. Any help please.
I'd try quick detailer to remove the streaking. I am pretty sure anything that will remove the wax will also remove the Klasse.
Try putting Klasse on your rims, I use Meguiars #20 and I can clean them with just car wash and a mitt.
Mothers clear coat polish or an aluminum/metal polish if they are not clear coated.
If you have 7 or 8 coats of SG, the dish soap will NOT remove them all. It may remove a coat, but nothing you should worry about with that many coats. Use the dawn, it will remove blitz and hopefully remove your hazing problem.
Like Red Wolf said, try using QD to fix the streaking before deciding to remove all the wax. Unless of course, the streaking is everywhere.
Dawn or dish detergent doesn't really budge Klasse. If it does, it's super slow. Intel486 and I both tested this out, and I only did it on 3 (4?) coats.
Try tweaking your Blitz application routine. Quite a few people use Blitz over Klasse and I hate to see this kind of thing happen. Good luck. :)
I figured it wouldn't harm the Klasse. I tried the Qd, for weeks on end. It's just something with the humidity down here that makes the wax look hazy and oily. well, tomorrow the wax will ciome off. Maybe I'll just add a few more coats of SG. Hehe!!! i havent had this problem with 3M show car wax. Man what a shine. Dosent last too long though.
