craigdt said:
Where do you guys get the mf bonnets?
I forget where I got my Meguiar's ones, but any Meg's distributor should be able to get those.
I got most of my other ones from
Top of the Line Auto Detailing Supplies . Griot's has them too, but I haven't tried their current offerings.
One factor to satisfactory removal-by-bonnet is the pad you use (the bonnet fits over the pad). Some bonnets (Cobras come to mind) are sized so that they fit best with a wool pad, but IME the wool pads tend to squish down and stay compressed, offering less and less cushioning with continued use. Thus I prefer to use a foam pad, but it can take a little experimenting to find which pads work with which bonnets.
No such problem with the Meguiar's bonnets, which work great over 7006 (burgundy) cutting pads. Griot's sells a special foam pad just for use with their bonnets, so there shouldn't be a problem there. My suede-style ones from TOL work well (on the Cyco) over yellow foam cutting pads. With others, you'll just have to see.
Watch for the bonnets getting loaded up, which doesn't always happen uniformly. Be careful about turning them inside out to use the other side, lest bits of the pad be stuck to the MF and cause marring (especially if you use wool pads or that Meguiar's 7006).
