Jesstzn said:Send the towel to me to see if I have the same problem. Where did you buy the towel?
Pakshak. Send it to you?? If you'll send me two then I don't mine sending it to you
C-MDX said:I don't know if this is the reason but I hope it is since I can repair it but is it because I use too much Dawn when I wash it and I didn't rinse it well so residue is sticking on the cloth?? If so, can I remove the residue but rinsing it in warm to hot water?? Or is it better if I put it in a hot bucket a water and let it soak overnight??
Jesstzn said:Throw it in the washer on the cool rinse cycle then hang to dry.
JimS said:I use pakshaks ww towels and have NEVER had any kind of problem.
C-MDX said:Jesstzn, are you sure that works?? If so I'll do it tonight right after I get home. BTW, I can throw all my MFs in there too right??
Jesstzn said:Should rinse out the soap residue. Thats what I do woth mine I wash them by hand in the laundry tub in Dawn then throw them in the washer in cool rinse. Then hang to dry
k2dan said:Ease up MDX im with you...................Look i think the answer is simple but I may be wrong. I thing you think that the WW will gobble up masses of water and leave no water trails..................they dont.
Most of the professionals here eithier use 2 towels or make sure they dont have large volumes of water to soak up.
WW will leave trails of water when saturated....end of story.
Lynn said:I think you're making assumptions k2dan.
I don't have a clue why C-MDX is having these problems with his WW, but I don't think you can just dismiss everybody else's success as some kind of "magic."
Not meaning to attack anybody. But, k2dan, it doesn't sound to me like there's a simple answer. Those of us who have had success aren't using any magical tricks. And it doesn't sound like C-MDX has made any mistakes. Which is why most of us seemed stumped as to why his experience is so different (and worse) than most Autopians. We're just trying to help analyze the source of the problem.
Lynn said:As I hope you can hear here, many of us are truly perplexed by your experience, because it's so different than ours. If I were in your shoes (or if you were just down the street from me!), I'd put those puppies in the washer with NO detergent. Run them thru a full cycle -- and if you have a setting that lets you do a double-rinse, opt for that. Then let them line dry.
