tricycle said:Okay, do you mean I should let those "streaks" stayed on the paint and let them dry (at least 24 hours) so that they easy to wipe off? Is the the common practice of the KSG?
Also, when you say moistened the application, do you use water or quick detailer?
Thanks.
Not exactly.
If you have the time (overnight), then I would apply the SG to the entire car, and go to sleep. Come back the next morning, and wipe off the SG using an MF or 100% cotton cloth (I've actually had better results using cotton to remove the SG - but that's my personal experience). Of course, this is assuming that you have a garage, where the car can remain undirtied overnight.
The other option is to use WOWO. I typically apply the SG using a moistened applicator. I use an applicator made of sponge material covered with a MF fabric covering. I completely soak the applicator, and then squeeze as much water out of it as possible. I then apply a couple of drops of SG and start applying to panels.
As soon as I've wiped the SG across a section of a panel, then I wipe it back off again. I do very small sections, so this may explain why it is easier to wipe off. I typically do the roof in 4 sections, hood in 4 sections, trunk in 2 section, and then each quarter panel and door in 1 section.
If the SG has dried enough to be 'sticky' and difficult to remove, then I rewipe with the moist applicator (with the right hand), and immediately wipe off (with the left hand). This process has resulted in a great, streak-free appearance on my black car.
As for the speculation of new vs. old formulations, I have been using an 'old' bottle, but I have a 'new' bottle on the shelf. I'll try to check out any differences over the weekend (after I wash the car).
