Question: Werkstatt VS Poorboys???
I currently use Poorboys (SSR, EXP, Natty’s etc) and works VERY well; like it a real lot. Is there any way I can combine the two different manufactures? Also what would give a better gloss, protection, functionally etc on my black Lexus, on my motorcycle, and other cars and yes, my tractor?
My Werkstatt order comes tomorrow (can’t wait) and wondered if I should stick to one or just keep using both?
I only ask since I keep trying more and more products and want to stick to one or two tops..You people are a bad influence!!!! LOL
Or these again maybe I should look in more directions????
:bigups
You can use the SSRs with anything.
You can always top JW's with Nattys.
You could put EXP over any variations minus carnuba of Prime and you can put over or under or alternate EXP with any of the AJ's minus carnuba.
Hope that helps.
So your tractor huh, what kind of tractor is it. I need to make sure that it is worthy of keeping nice. :LOLOL
I used to use ssr/exp/nattys and have recenty used AIO/werkstatt/carnuba jett and the werkstatt stuff is harder to use but the depth and flake pop over the poorboys is amazing. My new fav combo.
Yea, Werkstatt is my favorite, I have used Poorboys and for look and durabilty, it blows Poorboys out of the water. Application can be a bit finicky though...
Use Poorboy's for deep polishing since the Werkstatt polishes are not very aggressive and use JW to seal. Poorboy's is definitely better if you have to work in the direct sun though.
thanks!
I got my JW items today (only prime strong and AJT). Now is Nattys Blue over AJ Trigger (AJT) good? Or AJT with CJ or AG/CG bettter?
Maybe I will just order it and call ita day. :p
That is great information for me too.
Thanks. :spot
Are the PB polishes okay for use in direct sun, or any others for that matter? EX-P has definitely made my life a lot easier in that regard..
Nothing wrong with detailing the tractor, I do it alot and keep mine very nice. I use up all my old crap , QD spray , wax ect on it.
2001 John Deere 445 , power steering , tiit wheel , cruise control , adj.seat , locking rear diff , 54" deck , 26" rear tire's 12" front's. 22hp fuel inj. A real joy to cut grass and snow plow with.
Anyway I like working with PB stuff and am interested to see how you like the Werkstatt stuff.
Not sure why many people say that Werkstatt is hard to remove. I had no problem at all applying and removing it. I'm sure if you work it in well enough, it should be easy to remove.
As far as Carnauba Jett, for me, I worked with two MF towels. One to wipe on, one to wipe off. Can't get any easier than that.
Prime isn't very abrasive so I hope you're not thinking that it will remove swirls. However, it brings out the depth of the paint, especially if you use Prime Strong.
Thanks. I had a 455 and got a Kubota BX22 (old school model now). I clean it about 3 times a year. So far looks brand new. Also I am sure people with think I am nuts but I also but HIDS on it!
But, so far Werkstatt is easy to remove. I only have prime strong and AJ trigger. Both are very easy to remove.
So far after a week against both. AJT beads smaller in rain & smoother. It really is a toss up so far....I like JW more for some odd reason. Maybe less steps.....................
color seems the same but gloss might be a little more with JW. Depth is also more I think with JW
