I recently pruchased a PC7336 from Lowes. Used it for the first time this weekend and did not get the rsults I was hoping for. Which brings me to my question... It seems that the "head" is not rotating at all, just vibrating. I used a tip from someone to draw a little dot on one of my pads and see when it stops rotating, when it stops you are applying to much pressure.
Well I apply not pressure at all and just let the machines weight on the pad and it stops rotating. If I left up a little it then begins to rotate.
Am I doing something wrong here? I am using the edge 2000 pad kit with the quick connect adapter. Any help is greatly appreciated.
