Carl Anderson said:
I think the main advantage to QEW is time, and not having to drag the hose out and use all that water. I think it just about cuts my washing time in half, and that gives me more time to do other detaing projects.
I agree...
~One manâ€â„¢s opinion / observations
Q: After reading many, many thread on QEW, I think the main differences between QEW and regular car wash soap is; QEW has fewer suds, releases dirt from the mitt easier and does not require a separate rinse. Is this correct?
A: QEW contains an Anionic, which is a synthetic agent that provides very low foaming (suds) with very efficient surface rinsing, while avoiding any re-depositing of the soils and eliminating any chemical surface â€Ëœfilmâ€â„¢
Q: Does QEW provide greater ability to lift soil from the surface?
A: Yes as QEW has a particular type of molecular structure that performs as a surfactant, these molecules form micelle structures; the hydrophobic (water-insoluble) hydrocarbon holds solids in suspension and prevents them from being redeposit. The hydrophilic (water-soluble) ionic reduces the soils to micro-sized particles to enable them to be flushed away.
Q: With a soil load on the car considered workable with QEW, would this car washed traditionally have a reduced risk of marring?
A: Yes as most car wash concentrates use synthetic cleaners that contain a surfactant
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
