Setec Astronomy
Well-known member
We’ve got them at nearly every connection point (auto repair shop). I should probably know this, but it’s always been handled by maintenance/other people - what’s normal shop line pressure?
Off-topic: That compressor setup sounds like mine, great for use with a Lonn Cleaning Gun. Gee, is that psi considered high for a Shop? Mine`s right around there (a bit higher but doesn`t maintain it under full draw).
It all depends what you`re doing...it`s just that usually you maintain the receiver at high pressure for several reasons (capacitance and condensation) then you regulate down to a lower pressure for distribution, and then a lower pressure at the point-of-use--so maybe that 130 is already the secondary pressure. I would say that 60-100 is the "normal" industrial range in the secondary/distribution part of the system...part of the reason for that is to minimize leakage losses and consumption at things like blowguns if they aren`t regulated at the point-of-use.
