imported_Aurora40
I realize this is insanely old, so I apologize. But I thought an update would be useful.
For a long time I used this product with an el-cheapo spray bottle. It sprayed out a glob, and I'd wipe it on with a foam applicator. As a result, I found the product not so useful.
For one, the car had to be clean first, as I was wiping it. For two, you can't get that much on. Eventually I had a Meg's QD bottle (the maroon ones) that was empty, and I cleaned it up and put the Bug Guard in it. It works much much better this way. The sprayer sprays a mist, and I basically spray a coat on just like if you were painting the car. It goes on much much thicker this way, and also you can put it on a car that is dirty. So you can spray it on on the start of a roadtrip (where maybe your car is clean) but can also spray it on for the return trip, where maybe your car is not clean.
I did this on a ~700 mile each way trip on the Aurora and Corvette, and it worked like a charm. Bugs rinsed away easily after each leg of the trip. I only use this stuff on road trips, not all the time, but it works great for what it is.
