alfredeneumann
Hi, I have a question and don't want to come off sounding too too paranoid. See I have a few small dents (about 5 of them) on different parts of my car - door panel, trunk hood, front quarter panel, etc. I would be interested in taking it to a professional paintless dent removal place and having them try to fix these dents. The problem is, from what I have seen is that these places use rods and levers to push the dents out from behind. The thing is, the only thing I hate more than dents and bad paint is RUST. If they're using rods, say in door panel (I assume they are sneaking them in where the window goes) and pushing against the metal from inside, I am sure they will scrape any inside paint or coating. Several years from now I am sure that rain from the window and just moisture in general will act on that inside scrape, cause rust, and I will eventually have a hole in that door panel from rust. Is that a realistic assumption or not?
Generally I don't like people opening things and taking parts off the car to get to things inside because usually I have a hard time trusting people that they will do it carefully enough so as not to scrape any existing paint, coating, etc. Because if they scrape anything, then rust will set in pretty soon.
Can anyone share their experiences with this - and particularly in respect to scratches from the rods and resulting rust?
Also, one more question. On one of the dents, the paint is beginning to crack at the top of the fold. The crack is about the size of a needle head. Can this dent be repaired or does this indicate that rust has already attacked the metal and thus I need to sand off all the paint in that point and the surrounding area and then primer, paint, and clear coat before I can have that dent repaired? Note that all of this was not my fault. I bought the car used (2 year old car) and I do not know how long the dent has been there. I was not the negligent one in this case, just to be clear.
