TroyScherer
Ummm.... Ya.....
Troy - just wanted to check in with you to see if you have any other application tips/update on Cquartz. I've wet sanded a few panels on my car and want to put back a few microns, so I've purchased CQuartz UK to be applied later on this week
Thanks in advance...
Glen,
I personaly found CQuartz easy to use and apply. I worked smaller areas only doing ½ a hood at a time, or even smaller depending on conditions.
I redid this same car with CQUK in late summer / early fall. That means that original CQ last 2-1/2yrs. I found CQUK even easier to apply than CQ orig. I began working a small area and keep spreading it out until the “rainbow hazing” was almost all gone. I then let it “flash cure” for a few minutes and then very lightly buffed the panel removing any “high spots”. Since I had a garage I let the 1 layer sit for a few hours and then applied a 2nd layer. I applied the CQ very heavy handed a few time on purpose and found it still easy to spread and level. I then waited another few hours and then applied ReLoad as directed. I was verycarful but used a little extra ReLoad when cover the CQUK. I didn’t worry about a few streaks I got as there were no “high spots” before applying ReLoad. I waited 1 ½ weeks to the CQUK cure before washing.
I am actually planning on doing a deep clean on the coating in the spring and apply layers 3 & 4….
If you follow the instructions and some of the application videos available you will be fine.
<Video from CarPro on the application> CarPro Professional Car Coatings - CarPro Global - CQUARTZ CQUK
Cquartz CQUK - YouTube
