Problems with dust and chunking up of compound
pnut
Using 7424 to remove a few fine scratches on my roof. Pictures tell most of the story, but here are the questions:
1) Why is the material "chunking" up so much on the roof (see the picture)? I am thinking too much compound.
2) How much compound should I be using? I finally settled on barely enough to make the surface have haze as I moved over it, but usually only in the middle of the pad stays wet (after the chunking picture I reduced qty of stuff).
3) The white pad has 3m swirl mark remover, I used very little material and applied it to the outer edge, but no matter how I apply it, the center gets loaded, and the outer edges go dry (same with the compound). Why is this?
4) I have HUGE amounts of dust from the compounding, is this normal? It makes an awful mess and now I need to wash the whole car all over again.
I actually just bought some 4" pads witha 3.5" backer to try to resolve the problem I have of the center getting loaded, and outer edges going dry.
wannafbody said:
Way too much. Use about 6 pea sized drops. Work a 2'x2' area until clear and then wipe off.
Im with you way too much. The dust is normal I allways rewash after heavy compounding.
I would wash the pad out. Clean the car off, and clay it to get a super smooth surface. Apply just a little product to the outer edges of your pad , work the P/C using the outer edge of the pad. Use a instant detailer to mist the surface. This will allow you to work the compound longer without adding more. Yes dont try to cover the whole roof in one pass. Rigorously work small sections at a time.
