Pro Polish after painting something myself?
91LSMAN
2002 Chevrolet Corvette
Ok, here is the thing. I'm thinking about buying eyelids for my Legend. When I buy them, instead of taking two small pieces of plastic to a body shop for paint I think I may paint them myself in my garage. I would be buying the paint/primer from paintscratch.com and they say:
Our paint requires a final polishing with rubbing compound (which we sell on our site) to make the paint glossy. Do not use polishing compound, it is not aggressive enough to polish the paint. There is a big difference between rubbing and polishing compound. Also, do not use heavy duty rubbing compound as this is too aggressive and will dull your paint. If you are spraying a large area, we recommend having the area machine polished as trying to polish the area by hand would be time consuming and require considerable pressure to obtain the proper gloss. You can use polishing pads with your electric drill, or go to your nearest detail shop and have them polish it for you. Machine polishing takes skill and it's very easy to burn right through the paint. Our rubbing compound can be applied by hand or machine.
So my question is, if i decide to take this on myself, after the paint/clear is dry could I use PP to make it glossy?
