Pro Launch
  • Thread starter Thread starter Ben@3D
  • Start date Start date
B
Ben@3D
Guest
Hey Guys,
Just wanted to let you know that the HD PRO is officially Launched. All products are in stock and ready to ship. :spot
HD PRO LINE LINK
I'm a little confused, the HD Protect Pro, shows a 64oz bottle but under the description it shows as 24oz for $49.00. I assume given the item# HD-PROTECT-64 that it is 64oz?
Also the HD Dressing Pro has the item# HD-DRESSING-64, but under the description it shows 32oz?
Thanks for noticing those. :up They are both 64 oz bottles. Fixed the typos!
We will be selling 32 oz empty spray bottles for each however and should be up this week.
is that the Meg's wool pad?
Does it shed?
Your orange "polishing" pad - is that a real (soft) polishing pad in orange color or the same as the UNO pad?
No its the new HD Wool Pad designed to work as good or better due to two type of wools combined to work with the HD UNO . It being designed with shorter wool threads so it will shed but not as much as a regular wool pad. The orange pad is not soft but it is designed foam for polishing now the blue foam pad is soft that pad is designed soft for the HD Poxy for sealing or wax appication.
Does it shed?
