Jon S said:be careful. it does work as advertised, kept on using it but before i knew it, the wiper actually tore on one end. while it still looked good at wiping, before i knew it, the torn side scored the glass from the metal holder.
On the back it says propylene glycol. Sorta close, but not the same. It also says to apply 2 coats and suggests a curing time of 24 hrs for best effect. I guess it actually does coat it with something...Home run Hero said:I believe it's just isopropyl alcohol and perhaps is cheaper if purchased as such.
