I'm about to go after some rock chips on my hood with an autosharp pen and am wondering the appropriate prep work.
Specifically, I have a couple layers of 845 down which is still beading well... will this be a problem adding touch up paint over it?
I was thinking I should probably use some rubbing alcohol or something to cut straight to the paint on those areas followed by a water cleaning. Is this necessary?
Depending on how the application goes and how close the paint matches, I may try over filling the chips and wet sanding.
Any suggestions are appreciated.
