Potential *pit marring* from blow drying
Considered add the Metro to the stash last week....decided not too. I thought about how I would use it, etc and it would probably be one of those things where it just kinda sits around..The blower to me, is just way more efficient in terms of drying time ....and no hose to coil back, etc. I did like the rubber tip though ;-). Just on my honeydo list to make one for the leaf blower...
I don`t think this is a legitimate concern. I live in NE PA where they use lots of salt - and I have no idea what salt smells like - and have never smelled it in the air.
You are not damaging your car by air drying it in the winter correctly.
Sent from my iPad using Tapatalk
Ray -
You can only pack so much juice within a given sized cell.
I would not say battery technology doe not need to bemoved forwarded, as technology constantly evolves, but at this point in time, batteries are where they are.....aside from getting heavier in packing more *juice* within it`s respective voltage platform. Weight correlates as well.
It really is all about the tooling.
Aside from a detailing nut, I`m a tool wh0re....
My Hilti Corded, Metabo Grinders, etc gather dust.
I`ve got about 30 Milwaukee Batteries on deck.
It powers all the usual stuff like impacts drivers, but who would ever imagined Hole Hawgs, Grinders, SDS VAC controlled Drills, KO cutters, Porta Band, Lighting Systems, etc. The list goes on.
Hence, I did not buy the Metro I briefly considered...
Why go corded when I can go cordless...
It`s all subjective at the end of the day. Some factors like ROI on batteries, etc to be considered
Ray -
...okay
aside from being an engineer... im a detailing whore... i will wait until i am satisfied with the battery performance before i go buy one. not sure what our discussion is leading and i am not sure what you are trying to convince me of...
It`s just semantics Ray. Good CFM - movement of air, is relative to the blower wheel....
If you want small footprint as per your other post, between cars, master blaster is the way to go....
For me, not a fan of the cord but that`s just due to how I operate it....
THIS! ;)
The *key* with a corded (or battery powered) blower is CFM, CFM, and uhhhhh CFM. The smaller the final opening, the faster the air moving through that opening. However.... with CFM you are moving *volume* of air through an opening, (usually a larger opening than a faster `speed` blower has).
What I`ve been kicking around is building a dual electric blower setup with a 20~30 foot hose. I could do a setup where both sit in the bottom of my detailing cart, attached to a Y pipe (say a 4" PVC unit). Then do a reducer to a 2" hose (similar to what you`d find at the local coin op car wash as the vacuum hose), then do a typical conical attachment on the end of the hose. It`d be easy to build, and IF you want filtered air.... you could put the blowers (without their long extensions on them) in a plastic container with a snap on top, and mount a HVAC filter on the top so that they would only have filtered air (and you could even change the filter if/when it showed signs of dirt). I was just thinking of one without the box to put them in, but they`d fit in a box no problem. Don`t really think they`d need the filter... but hey... it`d be an option for sure.
The total build cost would be MUCH LESS than a `blaster`, with the bulk of the cost being the second blower and the hose. (Quality hoses run anywhere from $60 to $150.)
You`d end up with the ability to run it at 4 speeds. One unit running on low. Two units running on low. One on low, one on high. Both on high. The CFM and MPH would be AWESOME and it`d be something that could be put together in an afternoon (including the trip to Lower/Home Depot for parts). ;)
Slightly off topic...
But do you guys use any specific car blow dryer out there... or do you just use a standard leaf blower, etc?
:confused:
I have a Master Blaster, a Metro Sidekick, & a Kobalt 80v Li ion blower. Former owner of a Metro Air Force blower.
Master Blaster: Works well. Very powerful. However, design is cumbersome and hose is very stiff - making it a PIA to use and store. Prolly good if you have a detail shop - if not; storing it, dragging it out, and dealing with the hose and the cord (while going around a car) is a supreme PIA in my opinion. It`s now become an ornament on the shelf.
Sidekick: Great! Perfect! Bravo! Awesome for drying any little thing or blowing water out of crevices. Prolly everyone should have one of these. Design & ergonomics make it a pleasure to use.
Kobalt 80v Leaf Blower (powerful cordless leaf blower): only thing I use anymore. Simply because it`s quite powerful - and - NO CORD! Just pick it up, push a button, and use it. That`s it. Battery charges fast and lasts > 45 mins. 3 speeds - nice. Beauty of this is, you can also use it around the house to blow leaves. Not quite as powerful as a MB, but much easier and quicker to use.
Sigh...seems like I`m still the only guy here using an AirWand for my forced-air drying :( !Oh man! do I like that thing.
I have the handheld master blaster and it`s amazing. I actually just got done using it. It also heats up the air a little.
