Porter Cable 7424XP
If you do NOT put a screw and a washer in the hole the black cap cover will slide right off!!!
It will slide right off the front. You will have a black cap in one hand & a machine in the other.
Although this could be interesting and exciting while you are polishing...it is not a good thing.
(Don't ask me how I know)
Even the GG 6" has the same requirement. It has a U shaped handle with a bolt on each side.
I remove both bolts and discard the handle. Then I replace both screws into the machine head.
