Pretty much wipe on,15 seconds wipe off. Let first coat set for 1 hour,second coat,let set for 4 hours and apply different final coat. This can be accelerated with an infra red lamp.
12/24 hours for water,7 days for soap.i have found out that letting it set to long,or missing a spot,it requires machine polishing to re do. This is probably the hardest coating I have used when it cures. As you know we used finest, if there was a high spot,you could polish it off with a hand polish. Not with Gyeon , it requires a machine to remove. If you take your time,lots of light, it is very easy to use.i have had more compliments on my black challenger,since using Gyeon than ever with finest.customer service from Todd is excellent,the packaging is top notch,and the product is amazing. We have used c Quartz,modesta ,g tech,and several others. Gyeon is hands down the best we have tried!
