pontman43
I cant believe there aren't more votes for OCP! I love it!
Accumulator said:Using 4" pads will make a lot of products work more effectively when it comes to medium-severity marring.
mpmiller37 said:I see a lot of Menzerna votes out there, but have read in other posts that it can be difficult to use becuase it cannot be worked very long and starts dusting, maybe this only applies to their IP, and not the FP II ? But I need to remove some defects so I thought I would need IP ... not sure what this P085RD product is compared to IP ? Can it remove defects and is it user friendly, for say a PC newbie.
mpmiller37 said:I wanted some comments on popular polishes that perform well with a PC that remove medium or light defects. Give me ones that are user friendly, and to get more specific how about on "black" cars :2thumbs:
mgm121499 said:For PC use on Black I've had excellent results with Menzerna polishes.
mpmiller37 said:I can see the Menzerna removed the scratches but what are all those "white looking" dots ? Please comment on how long this polish can be worked and possible dusting problems.
JohnnyDaJackal said:*edit* for you PO85RD users via PC, do you get better results with a polishing or finishing pad? I seem to get the most slight marring, almost like FrizzleFry's after picture with everything I use. I'm wondering if I used a finishing pad with PO85RD instead of a polishing pad, if I would get rid of that ever so slight marring?
Richt said:For defect correction on Black with a PC I have had most success with Poorboys SSR 2 and 2.5 and DP Super Swirl Eliminator.
As final polishes Speed Glaze, Clearkote VM, and Optimum Polish.
SpoiledMan said:The "nano" polishes give their best shine with the rotary but will give pretty nice results with the PC and a polishing pad(W8006) and with longer work time a finishing pad. 99% of my use has been with the rotary and W9006 finishing pad and there isn't a buffer trail in sight anywhere.
Menzerna polishes are easy to use with the exception of PG which is still not difficult to use but does have a small learning curve. I don't have any problem with IP, FPII or the PO's being dusty at all. I use a sprits or two of water on the pads when using PG and that helps keep both dust and work time in check.
Coltagious said:Hi Richt,
In your opinion, is VM comparable in removing swirls or compounding haze as Op Polish? I read that VM contains fillers right? Can I also go straight to VM from, say OPC with yellow LC pad to VM with white polishing pad?
