Stokdgs
dansautodetailing.com
If you don`t load up a pad with too much of anything wet, and don`t turn it on to higher rpms from the start, you don`t get splatter...
If you put too much product on the pad and realize it after you started off slow, you should just spread it out farther on the panel, and that will take up more of it so when you might speed up the machine, it will not throw a bunch of product out all over the place..
Even on the L/C Purple Wool Foam Pads I use only for really hard defects, all Airplane paint, etc...
I never get splatter because I choose to not make it happen..
Then, the other end of it - dusting - Why?
Just don`t let it dry out and then you have no dusting...
I never get dusting either..
If one will take the time to almost completely or completely use up all the product on a foam pad and keep the pad flat on the panel the entire time, there is less chance of leaving anything on the paint except perfectly clear, flat, gloss...
If one sees defects in the paintwork while you are doing it, don`t you want to work on those defects until they are gone ?
This where great lighting really helps..
I keep the speed below 1,000, so there is more time for the product, pad, and paint, to get to know each other the longest, and not dry out quickly.. Sometimes when I see the work starting to dry and hear and feel the machine starting to change, I stop and spray a little pad conditioner on the spot and keep going until the everything is about gone on that spot.
The pad picks up whatever is left, and I take a white clean towel and wipe the pad face down and look at what came off..
This allows the pad to go longer on the work until it may eventually get too much dead paint etc., in it, and it soaked up too much pad conditioner, product, and it no longer works as when I started, so I change it out..
The panel I just corrected has very little if any product left on it, so when I wipe it off with a clean soft microfiber, there is very little chance to introduce something onto that spot that I just made perfect.. Less you touch it, the better..
Dan F
Dan F
