Pinnacle Advanced Swirl Remover
redhotzx9
I was wondering if anyone knew what the the equivalent to Pinnacles Advanced Swirl Remover would be. I want to try it out but I dont know if it is to abraisive. Thanks.
I would like it to something like SSR2.5 It's a decent polish, but not my favorite. It's been a little while since I've used it.
ASR for a point of reference would fall somewhere between 2.0 and 2.5. It is a good polish, but you might be even more pleased with the results of the new XMT polishes. They are formulated specifically for machine use and can also be used in the sun. I hope this helps you. :)
YES, the Advance swirl remover is more in the range of the ssr2.5 if use with a light cutting pad, you can remove moderate to severe swirls. You can also use it with a cutting pad for those stubborn swirls but make sure to have the finishing polish handy to remove some of the micro marring. :howdy
