EdLancer
I don't know if my eyes are playing tricks on me or not, but I have noticed on many occasions that the PC with round out or eliminate linear scratches faster than with a rotary. Has anyone else noticed this ?
EdLancer said:6.5" even !
EdLancer said:I don't know if my eyes are playing tricks on me or not, but I have noticed on many occasions that the PC with round out or eliminate linear scratches faster than with a rotary. Has anyone else noticed this ?
Carbon Blue said:really? With my udm on speed 6 and a 6.5inch pad it begins to orbit more than rotate. Ive used 4inch pads and theyve only lasted me about 3 hours worth of use before they disintegrated![]()
cushdrive said:All those results showed was that it took much longer for the PC to level the paint, and when the PC finally got the paint to a state of perfection, it also caused more damage to the clear.
superstring said:Ed, if you haven't already, have a look at this. You may find your answer.
http://www.autopia.org/forum/car-de...-removes-more-paint-answer-may-shock-you.html
David Fermani said:I just can't see a PC being superior to a rotary for scratch removal. Are you positive of your results?
EdLancer said:Wow, someone already did a nice study on the issue !
I would agree that the rotary has more power in removing defects, but it is the technique that is important, if you use a rotary on a defect without moving it is "all" directions with some velocity then no its not going to remove the defect as fast as a PC, the PC works the spot in all directions even without moving it. So this could be the case I suspect.
