imported_dfw
I just picked up a 7424 and it says to "Use 5 inch Pad Only". Can I use 6.5in pads? I never seen this before :think:
dfw said:icic.
Which 6" backing plate should I use? What about this
Porter-Cable Backing Pads, Polishing Pads & Counterweights
or these
Hook And Loop Backing Plates feature Velcro brand hook & loop fasteners to hold foam pads in place. lake country backing plate, lake country foam
If I get the 6" backing plate, do I need a counter weight as well?
D&D Auto Detail said:Go with 5.5" pads with the PC. Itll correct better.
toyotaguy said:I actually prefer to use a 6" plate with 6.5" pads and a 5" plate with 5.5" pads and a 3.5" plate with 4" pads...
call me crazy, but I have more control and it doesnt bog the PC down as much as a small plate with a bigger pad...(5" plate with 6.5" pad), not to mention faster results
lexusgs said:Also I do want to do some correcting but some are saying it is better to go with smaller backing plates and pads for this. I was planning on getting a 5" flexible backing plate and using similiar sized pads Is there a big difference between different makes of these flexible backing plates? I have a black Lexus GS430 and would like to get rid of swirl marks, oxidation, water spots, small scratches, any recommondations on pads/polishes to accomplish this.
