Pc 724xp
kpinks
I am considering buying a Porter Cable 7424XP polisher. I am not sure what polishing pads to buy for this. Can I get the quilted "foam" pads for this machine? I have attached a pic of the pad. Also are there any tips and tricks or guidelines for the 7424XP polisher, that may tell me a bit more about things like what speed and polish to use?
Thx
Kev
Those pads will work fine with a 7424XP; you'll just need a 5" backing plate to use them with.
Those pads come in anything from 4" to 8.5". I, along with most others here, recommend the 5.5" variety which come in 6-packs for $34.99.
Lake Country 5.5 Inch CCS Pads 6 Pack - Your Choice!
The 5" backing plate (LC-43-125DA) can be found here -
Porter Cable 7424 Backing Plates- Dual Action Hook & Loop backing plate for your porter cable 7424, The best backing plates for the Porter Cable 7424
A good start would be 2 orange, 2 white, and 2 gray pads just to have some variety.
Check out the Show Car Garage link at the top of our site - there you'll find videos with Mike Phillips which go in-depth as to what polishes, pads, speeds, pressure, arm movement etc to use when polishing paint, applying wax/sealant, etc.
Matt
