Eisen Hulk
Good deal. Once I have my own rotary, I'll look into the wave pads, but for now, I'm stuck with the CCS pads. I have the entire line-up, so I should be in good shape. You may have already mentioned this, but what about RPMs with UF/Red...I'm thinking 1k-1200? That sound about right? Also, are you applying it to the pad or are you picking up the bead? Finally, do you run a consistent RPM, or do you move it up and down? Sorry for the questions.
He only wants the exterior, which is nice because I'll be able to dedicate an entire day to the outside. I'll probably start out with IP/white and see how that goes, and then step it up from there. It'd be nice if I could two step it, but I doubt I'll be that lucky.
Thanks again for the assistance, Bee. It always very much appreciated.
SuperBee364 said:The only difference that I'm aware of is that the wave foam runs a bit cooler. I'm so gun shy with heat and foam pads, that I'll take a few degrees cooler wherever I can.
Also, Greg and I were very surprised at how well the red/UF comibination cleaned up after the mess the 105 left. The paint was sooooo soft, there was no need for an intermediate step; going straight to UF/red cleaned up the mess and left us a gorgeous finish. Honda paint is soft, but i don't know if it's soft enough to pull the same two-step process off. It *might* be, depending on how well you get the 95 to finish down. Looking forward to your CnB on it, Casey!
